11-25-2013 02:28 AM - edited 07-04-2021 01:19 AM
I have searched about the MTP VALUES for this particular AP and I got this thruogh CLI:
2.4GHz:
ap(config)#interface dot11Radio 0
ap(config-if)#power local ?
<4 - 16> One of: 16 13 10 7 4
maximum Set power to allowed maximum
5GHz:
ap(config-if)#interface dot11Radio 1
<5 - 23> One of: 23 20 17 14 11 8 5
Are these MTP values (16 & 23) in dBm or mW?
May I got more than these values?
Solved! Go to Solution.
11-25-2013 03:00 AM
Its in dBm.
Please check this doc:
https://supportforums.cisco.com/docs/DOC-13181
Dont forget to rate helpful posts.
11-25-2013 01:20 PM
Maximum Transmitted Power level MTP:-
The radio 802.11b, with country code EMEA (EU) (-E), and allowed power levels: 13 10 7 4 dBm, and Allowed Client Power Levels: 13 10 7 4 dBm While The radio 802.11a, with country code ETSI (OFDM) (EU) (-E), and allowed power levels: 23 20 17 14 11 8 5 dBm, and Allowed Client Power Levels: 23 20 17 14 11 8 5 dBm. ~ ETSI has more power levels than EMEA. I believe this cannot be changed as this is factory burned in hardware information.
The maximum power setting will vary by channel and according to individual country regulations.
11-25-2013 03:00 AM
Its in dBm.
11-25-2013 01:20 PM
