AIR-CAP1552E-A-K9 outdoor MESH AP
All I have a customer requirement to install outdoor Mesh AP AIR-CAP1552E-A-K9 ,at the site WLC 5508 running with ;Software Version 7.0.250.0. can any help me; the IOS which is running on the WLC supportMESH AP AIR-CAP1552E-A-K9 or it required to upgrade the WLC IOS Also below EOL I am ordering , would like to check the EOL is good anything I am missing Part Name AIR-CAP1552E-A-K9 802.11N Outdoor Mesh Access Point, Dual band Ext. Antenna AIR-CORD-R3P-40NA= Power cord, 40 ft, North American Plug AIR-PWRINJ1500-2= 1520/1550 Series Power Injector AIR-1520-BATT-6AH 1520/1550 Series Battery Backup Unit AIR-ANT2547V-N 2.4/5 GHz, 4/7 dBi Omnidirectional Antenna AIR-ACCPMK1550= 1550 Pole Mount Bracket Kit GLC-SX-MM-RGD= 1000BaseSX Multimode Rugged SFP module S155W8K9-12423JA 1550 Software Load Version
1 ACCEPTED SOLUTION
VIP Purple
Yes, 1552E will support from
Yes, 1552E will support from WLC 7.0.116.0 onward. See below for detail
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
I would check the country code configured on WLC & ensure you are ordering correct regulatory domain AP based on that.
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1300-series/product_data_sheet0900aecd80537b6a.pdf
here is the outdoor AP comparison page for your reference
http://www.cisco.com/c/en/us/products/wireless/buyers-guide.html#~outdoor,
Rasika
**** Pls do not forget to rate our responses if it is useful ****
VIP Purple
Rasika
AP AIR-CAP1552E-A-K9   S155W8K9-12423JA   should also work with 7.0.250.0. confirmed by cisco
however yet to deploy , will let you know
thank you
295
