05-28-2012 02:54 AM - edited 07-03-2021 10:13 PM
I have a 1552 E-A-K9 AP, connected to a 5508 WLC,Software Version 7.0.116.0. The problem i am experiencing is that all the existing P's on the WLC is working 100%, ( 1142's) but.
The 1552 does lease an IP adress from DHCP, and it does report on CDP neighbour discovery. I can however not ping the 1552, nor does it show up on the WLC.
Any body had / has the same problem?
Thank You
05-28-2012 09:03 PM
Did you add the mesh APs mac address to the mac filter? That is a requirement. Also you will still need to have the mesh ap join the wlc which is the same as non mesh APs. So you can use option 43, dns or place the ap in the same subnet as the wlc in order for the mesh ap to join. County codes are correct also?
05-29-2012 05:20 AM
Hi Scott,
I have added the AP's to the mac filter, and have set up the DHCP Scope option 43 as per Cisco documentation. I did "see" the AP on the WLC briefly, downloading and then it disapeared. i have the following Logs.
*spamApTask2: May 29 12:10:06.079: %CAPWAP-3-POST_DECODE_ERR: capwap_ac_sm.c:4573 Post decode processing failed for Config status from AP 2c:3f:38:be:36:40
*spamApTask2: May 29 12:10:06.077: %LWAPP-3-RD_ERR4: capwap_ac_sm.c:2480 Invalid regulatory domain 802.11bg:-E 802.11a:-E for AP 2c:3f:38:be:36:40
*spamApTask2: May 29 12:10:06.077: %LOG-3-Q_IND: spam_lrad.c:9471 Invalid country code () for AP 2c:3f:38:be:36:40[...It occurred 2 times.!]
*spamApTask2: May 29 12:10:06.077: %LWAPP-3-RD_ERR7: spam_lrad.c:9471 Invalid country code () for AP 2c:3f:38:be:36:40
Thank You for Your Help.
George
05-29-2012 06:08 AM
You need to check the country code... See the error below.
Scott Fella
Sent from my iPhone
05-29-2012 07:51 AM
Hi Scott,
I have added US to my existing contry code (ZA), and get the following when doing a debug capwap event.
Thank You for Your help.
(Cisco Controller) >*spamApTask2: May 29 14:25:35.566: Invalid channel 1 spacified for the AP AP2c3f.38be.3640, slotId = 0
*spamApTask2: May 29 14:25:35.566: Invalid channel 44 spacified for the AP AP2c3f.38be.3640, slotId = 1
*spamApTask0: May 29 14:25:36.182: 2c:3f:38:be:6d:a0 DTLS connection not found, creating new connection for 10:23:8:13 (59099) 10:23:255:129 (5246)
*spamApTask0: May 29 14:25:36.904: 2c:3f:38:be:6d:a0 Allocated index from main list, Index: 13
*spamApTask0: May 29 14:25:36.904: 2c:3f:38:be:6d:a0 DTLS keys for Control Plane are plumbed successfully for AP 10.23.8.13. Index 14
*spamApTask0: May 29 14:25:36.905: 2c:3f:38:be:6d:a0 DTLS Session established server (10.23.255.129:5246), client (10.23.8.13:59099)
*spamApTask0: May 29 14:25:36.905: 2c:3f:38:be:6d:a0 Starting wait join timer for AP: 10.23.8.13:59099
*spamApTask0: May 29 14:25:36.907: 2c:3f:38:be:6d:a0 Join Request from 10.23.8.13:59099
*spamApTask0: May 29 14:25:36.908: 2c:3f:38:be:6d:a0 spamProcessJoinRequest : RAP, Check MAC filter
*spamApTask0: May 29 14:25:36.908: 2c:3f:38:be:6d:a0 In AAA state 'Idle' for AP 2c:3f:38:be:6d:a0
*spamApTask0: May 29 14:25:36.908: 2c:3f:38:be:6d:a0 Mesh AP username 2c3f38be6da0.
*spamApTask0: May 29 14:25:36.908: 2c:3f:38:be:6d:a0 Join Version: = 117470208
*spamApTask0: May 29 14:25:36.909: 2c:3f:38:be:6d:a0 Join resp: CAPWAP Maximum Msg element len = 88
*spamApTask0: May 29 14:25:36.909: 2c:3f:38:be:6d:a0 Join Response sent to 10.23.8.13:59099
*spamApTask0: May 29 14:25:36.909: 2c:3f:38:be:6d:a0 CAPWAP State: Join
*spamApTask0: May 29 14:25:36.909: 2c:3f:38:be:6d:a0 capwap_ac_platform.c:1215 - Operation State 0 ===> 4
*apfReceiveTask: May 29 14:25:36.909: 2c:3f:38:be:6d:a0 Register LWAPP event for AP 2c:3f:38:be:6d:a0 slot 0
*apfReceiveTask: May 29 14:25:36.909: WARP IEs: (12)
*apfReceiveTask: May 29 14:25:36.910: [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
*apfReceiveTask: May 29 14:25:36.910: WARP IEs: (12)
*apfReceiveTask: May 29 14:25:36.910: 2c:3f:38:be:6d:a0 Register LWAPP event for AP 2c:3f:38:be:6d:a0 slot 1
*spamApTask0: May 29 14:25:37.033: 2c:3f:38:be:6d:a0 Configuration Status from 10.23.8.13:59099
*spamApTask0: May 29 14:25:37.033: 2c:3f:38:be:6d:a0 CAPWAP State: Configure
*spamApTask0: May 29 14:25:37.034: Invalid channel 1 spacified for the AP AP2c3f.38be.6da0, slotId = 0
*spamApTask0: May 29 14:25:37.034: Invalid channel 52 spacified for the AP AP2c3f.38be.6da0, slotId = 1
*spamApTask0: May 29 14:25:37.034: 2c:3f:38:be:6d:a0 Updating IP info for AP 2c:3f:38:be:6d:a0 -- static 0, 10.23.8.13/255.255.255.0, gtw 10.23.8.254
*spamApTask0: May 29 14:25:37.034: 2c:3f:38:be:6d:a0 Updating IP 10.23.8.13 ===> 10.23.8.13 for AP 2c:3f:38:be:6d:a0
*spamApTask0: May 29 14:25:37.034: 2c:3f:38:be:6d:a0 Setting MTU to 1485
*spamApTask0: May 29 14:25:37.034: 2c:3f:38:be:6d:a0 Finding DTLS connection to delete for AP (10:23:8:13/59099)
*spamApTask0: May 29 14:25:37.034: 2c:3f:38:be:6d:a0 Disconnecting DTLS Capwap-Ctrl session 0x14573db0 for AP (10:23:8:13/59099)
*spamApTask0: May 29 14:25:37.034: 2c:3f:38:be:6d:a0 CAPWAP State: Dtls tear down
*spamApTask0: May 29 14:25:37.035: 2c:3f:38:be:6d:a0 DTLS keys for Control Plane deleted successfully for AP 10.23.8.13
*spamApTask0: May 29 14:25:37.036: 2c:3f:38:be:6d:a0 DTLS connection closed event receivedserver (10:23:255:129/5246) client (10:23:8:13/59099)
*spamApTask0: May 29 14:25:37.036: 2c:3f:38:be:6d:a0 Entry exists for AP (10:23:8:13/59099)
*spamApTask0: May 29 14:25:37.036: 2c:3f:38:be:6d:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 0
*apfReceiveTask: May 29 14:25:37.036: 2c:3f:38:be:6d:a0 Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 0
*spamApTask0: May 29 14:25:37.036: 2c:3f:38:be:6d:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 1
*apfReceiveTask: May 29 14:25:37.037: 2c:3f:38:be:6d:a0 Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 1
*spamApTask0: May 29 14:26:37.072: 2c:3f:38:be:6d:a0 Received LWAPP DISCOVERY REQUEST to 00:27:0d:45:ae:4f on port '13'
*spamApTask1: May 29 14:26:37.072: 2c:3f:38:be:6d:a0 Discovery Request from 10.23.8.13:59100
*spamApTask0: May 29 14:26:37.072: 2c:3f:38:be:6d:a0 Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamApTask1: May 29 14:26:37.072: 2c:3f:38:be:6d:a0 Join Priority Processing status = 0, Incoming Ap's Priority 4, MaxLrads = 25, joined Aps =7
*spamApTask1: May 29 14:26:37.073: 2c:3f:38:be:6d:a0 Discovery Response sent to 10.23.8.13:59100
*spamApTask1: May 29 14:26:47.071: 2c:3f:38:be:6d:a0 DTLS connection not found, creating new connection for 10:23:8:13 (59100) 10:23:255:129 (5246)
*spamApTask1: May 29 14:26:47.241: Invalid channel 1 spacified for the AP AP2c3f.38be.3640, slotId = 0
*spamApTask1: May 29 14:26:47.241: Invalid channel 36 spacified for the AP AP2c3f.38be.3640, slotId = 1
*spamApTask1: May 29 14:26:47.786: 2c:3f:38:be:6d:a0 Allocated index from main list, Index: 22
*spamApTask1: May 29 14:26:47.786: 2c:3f:38:be:6d:a0 DTLS keys for Control Plane are plumbed successfully for AP 10.23.8.13. Index 23
*spamApTask1: May 29 14:26:47.786: 2c:3f:38:be:6d:a0 DTLS Session established server (10.23.255.129:5246), client (10.23.8.13:59100)
*spamApTask1: May 29 14:26:47.787: 2c:3f:38:be:6d:a0 Starting wait join timer for AP: 10.23.8.13:59100
*spamApTask1: May 29 14:26:47.788: 2c:3f:38:be:6d:a0 Join Request from 10.23.8.13:59100
*spamApTask1: May 29 14:26:47.790: 2c:3f:38:be:6d:a0 spamProcessJoinRequest : RAP, Check MAC filter
*spamApTask1: May 29 14:26:47.790: 2c:3f:38:be:6d:a0 In AAA state 'Idle' for AP 2c:3f:38:be:6d:a0
*spamApTask1: May 29 14:26:47.790: 2c:3f:38:be:6d:a0 Mesh AP username 2c3f38be6da0.
*spamApTask0: May 29 14:26:47.791: 2c:3f:38:be:6d:a0 Join Version: = 117470208
*spamApTask0: May 29 14:26:47.791: 2c:3f:38:be:6d:a0 Join resp: CAPWAP Maximum Msg element len = 88
*spamApTask0: May 29 14:26:47.791: 2c:3f:38:be:6d:a0 Join Response sent to 10.23.8.13:59100
*spamApTask0: May 29 14:26:47.791: 2c:3f:38:be:6d:a0 CAPWAP State: Join
*spamApTask0: May 29 14:26:47.791: 2c:3f:38:be:6d:a0 capwap_ac_platform.c:1215 - Operation State 0 ===> 4
*apfReceiveTask: May 29 14:26:47.791: 2c:3f:38:be:6d:a0 Register LWAPP event for AP 2c:3f:38:be:6d:a0 slot 0
*apfReceiveTask: May 29 14:26:47.792: WARP IEs: (12)
*apfReceiveTask: May 29 14:26:47.792: [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
*apfReceiveTask: May 29 14:26:47.792: 2c:3f:38:be:6d:a0 Register LWAPP event for AP 2c:3f:38:be:6d:a0 slot 1
*apfReceiveTask: May 29 14:26:47.793: WARP IEs: (12)
*apfReceiveTask: May 29 14:26:47.793: [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
*spamApTask1: May 29 14:26:47.915: 2c:3f:38:be:6d:a0 Configuration Status from 10.23.8.13:59100
*spamApTask1: May 29 14:26:47.915: 2c:3f:38:be:6d:a0 CAPWAP State: Configure
*spamApTask1: May 29 14:26:47.916: Invalid channel 1 spacified for the AP AP2c3f.38be.6da0, slotId = 0
*spamApTask1: May 29 14:26:47.916: Invalid channel 56 spacified for the AP AP2c3f.38be.6da0, slotId = 1
*spamApTask1: May 29 14:26:47.916: 2c:3f:38:be:6d:a0 Updating IP info for AP 2c:3f:38:be:6d:a0 -- static 0, 10.23.8.13/255.255.255.0, gtw 10.23.8.254
*spamApTask1: May 29 14:26:47.916: 2c:3f:38:be:6d:a0 Updating IP 10.23.8.13 ===> 10.23.8.13 for AP 2c:3f:38:be:6d:a0
*spamApTask1: May 29 14:26:47.916: 2c:3f:38:be:6d:a0 Setting MTU to 1485
*spamApTask1: May 29 14:26:47.916: 2c:3f:38:be:6d:a0 Finding DTLS connection to delete for AP (10:23:8:13/59100)
*spamApTask1: May 29 14:26:47.916: 2c:3f:38:be:6d:a0 Disconnecting DTLS Capwap-Ctrl session 0x14573f80 for AP (10:23:8:13/59100)
*spamApTask1: May 29 14:26:47.916: 2c:3f:38:be:6d:a0 CAPWAP State: Dtls tear down
*spamApTask1: May 29 14:26:47.917: 2c:3f:38:be:6d:a0 DTLS keys for Control Plane deleted successfully for AP 10.23.8.13
*spamApTask1: May 29 14:26:47.918: 2c:3f:38:be:6d:a0 DTLS connection closed event receivedserver (10:23:255:129/5246) client (10:23:8:13/59100)
*spamApTask1: May 29 14:26:47.918: 2c:3f:38:be:6d:a0 Entry exists for AP (10:23:8:13/59100)
*spamApTask1: May 29 14:26:47.918: 2c:3f:38:be:6d:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 0
*apfReceiveTask: May 29 14:26:47.918: 2c:3f:38:be:6d:a0 Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 0
*spamApTask1: May 29 14:26:47.919: 2c:3f:38:be:6d:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 1
*apfReceiveTask: May 29 14:26:47.919: 2c:3f:38:be:6d:a0 Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 1
*spamApTask0: May 29 14:27:47.678: 2c:3f:38:be:6d:a0 Discovery Request from 10.23.8.13:59099
*spamApTask0: May 29 14:27:47.678: 2c:3f:38:be:6d:a0 Join Priority Processing status = 0, Incoming Ap's Priority 4, MaxLrads = 25, joined Aps =7
*spamApTask0: May 29 14:27:47.678: 2c:3f:38:be:6d:a0 Discovery Response sent to 10.23.8.13:59099
*spamApTask0: May 29 14:27:47.678: 2c:3f:38:be:6d:a0 Received LWAPP DISCOVERY REQUEST to 00:27:0d:45:ae:4f on port '13'
*spamApTask0: May 29 14:27:47.678: 2c:3f:38:be:6d:a0 Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamApTask1: May 29 14:28:37.291: 2c:3f:38:be:6d:a0 Discovery Request from 10.23.8.13:59100
*spamApTask0: May 29 14:28:37.291: 2c:3f:38:be:6d:a0 Received LWAPP DISCOVERY REQUEST to 00:27:0d:45:ae:4f on port '13'
*spamApTask1: May 29 14:28:37.291: 2c:3f:38:be:6d:a0 Join Priority Processing status = 0, Incoming Ap's Priority 4, MaxLrads = 25, joined Aps =7
*spamApTask0: May 29 14:28:37.291: 2c:3f:38:be:6d:a0 Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamApTask1: May 29 14:28:37.291: 2c:3f:38:be:6d:a0 Discovery Response sent to 10.23.8.13:59100
*spamApTask1: May 29 14:28:47.288: 2c:3f:38:be:6d:a0 DTLS connection not found, creating new connection for 10:23:8:13 (59100) 10:23:255:129 (5246)
*spamApTask1: May 29 14:28:48.003: 2c:3f:38:be:6d:a0 Allocated index from main list, Index: 23
*spamApTask1: May 29 14:28:48.003: 2c:3f:38:be:6d:a0 DTLS keys for Control Plane are plumbed successfully for AP 10.23.8.13. Index 24
*spamApTask1: May 29 14:28:48.004: 2c:3f:38:be:6d:a0 DTLS Session established server (10.23.255.129:5246), client (10.23.8.13:59100)
*spamApTask1: May 29 14:28:48.004: 2c:3f:38:be:6d:a0 Starting wait join timer for AP: 10.23.8.13:59100
*spamApTask1: May 29 14:28:48.006: 2c:3f:38:be:6d:a0 Join Request from 10.23.8.13:59100
*spamApTask1: May 29 14:28:48.007: 2c:3f:38:be:6d:a0 spamProcessJoinRequest : RAP, Check MAC filter
*spamApTask1: May 29 14:28:48.007: 2c:3f:38:be:6d:a0 In AAA state 'Idle' for AP 2c:3f:38:be:6d:a0
*spamApTask1: May 29 14:28:48.007: 2c:3f:38:be:6d:a0 Mesh AP username 2c3f38be6da0.
*spamApTask0: May 29 14:28:48.008: 2c:3f:38:be:6d:a0 Join Version: = 117470208
*spamApTask0: May 29 14:28:48.008: 2c:3f:38:be:6d:a0 Join resp: CAPWAP Maximum Msg element len = 88
*spamApTask0: May 29 14:28:48.008: 2c:3f:38:be:6d:a0 Join Response sent to 10.23.8.13:59100
*spamApTask0: May 29 14:28:48.008: 2c:3f:38:be:6d:a0 CAPWAP State: Join
*spamApTask0: May 29 14:28:48.008: 2c:3f:38:be:6d:a0 capwap_ac_platform.c:1215 - Operation State 0 ===> 4
*apfReceiveTask: May 29 14:28:48.008: 2c:3f:38:be:6d:a0 Register LWAPP event for AP 2c:3f:38:be:6d:a0 slot 0
*apfReceiveTask: May 29 14:28:48.009: WARP IEs: (12)
*apfReceiveTask: May 29 14:28:48.009: [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
*apfReceiveTask: May 29 14:28:48.009: 2c:3f:38:be:6d:a0 Register LWAPP event for AP 2c:3f:38:be:6d:a0 slot 1
*apfReceiveTask: May 29 14:28:48.010: [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
*apfReceiveTask: May 29 14:28:48.010: WARP IEs: (12)
*spamApTask1: May 29 14:28:49.332: 2c:3f:38:be:6d:a0 Configuration Status from 10.23.8.13:59100
*spamApTask1: May 29 14:28:49.332: 2c:3f:38:be:6d:a0 CAPWAP State: Configure
*spamApTask1: May 29 14:28:49.333: Invalid channel 1 spacified for the AP AP2c3f.38be.6da0, slotId = 0
*spamApTask1: May 29 14:28:49.333: Invalid channel 44 spacified for the AP AP2c3f.38be.6da0, slotId = 1
*spamApTask1: May 29 14:28:49.333: 2c:3f:38:be:6d:a0 Updating IP info for AP 2c:3f:38:be:6d:a0 -- static 0, 10.23.8.13/255.255.255.0, gtw 10.23.8.254
*spamApTask1: May 29 14:28:49.333: 2c:3f:38:be:6d:a0 Updating IP 10.23.8.13 ===> 10.23.8.13 for AP 2c:3f:38:be:6d:a0
*spamApTask1: May 29 14:28:49.333: 2c:3f:38:be:6d:a0 Setting MTU to 1485
*spamApTask1: May 29 14:28:49.333: 2c:3f:38:be:6d:a0 Finding DTLS connection to delete for AP (10:23:8:13/59100)
*spamApTask1: May 29 14:28:49.333: 2c:3f:38:be:6d:a0 Disconnecting DTLS Capwap-Ctrl session 0x14574068 for AP (10:23:8:13/59100)
*spamApTask1: May 29 14:28:49.333: 2c:3f:38:be:6d:a0 CAPWAP State: Dtls tear down
*spamApTask1: May 29 14:28:49.334: 2c:3f:38:be:6d:a0 DTLS keys for Control Plane deleted successfully for AP 10.23.8.13
*spamApTask1: May 29 14:28:49.335: 2c:3f:38:be:6d:a0 DTLS connection closed event receivedserver (10:23:255:129/5246) client (10:23:8:13/59100)
*spamApTask1: May 29 14:28:49.335: 2c:3f:38:be:6d:a0 Entry exists for AP (10:23:8:13/59100)
*spamApTask1: May 29 14:28:49.335: 2c:3f:38:be:6d:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 0
*apfReceiveTask: May 29 14:28:49.335: 2c:3f:38:be:6d:a0 Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 0
*spamApTask1: May 29 14:28:49.335: 2c:3f:38:be:6d:a0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 1
*apfReceiveTask: May 29 14:28:49.336: 2c:3f:38:be:6d:a0 Deregister LWAPP event for AP 2c:3f:38:be:6d:a0 slot 1
*spamApTask2: May 29 14:29:58.972: Invalid channel 1 spacified for the AP AP2c3f.38be.3640, slotId = 0
*spamApTask2: May 29 14:29:58.972: Invalid channel 60 spacified for the AP AP2c3f.38be.3640, slotId = 1
05-29-2012 07:54 AM
You have AAA policy enabled fo AP join?
05-29-2012 08:02 AM
Hi Scott,
I have added the AP's MAC's to the MAC filter, the only policy enabled is MIC under AP policy.
Thank You
05-29-2012 08:09 AM
Can you put the mesh ap on the same vlan as teh wlc? if so, create a dhcp scope on the wlc for that subnet unless you have one already. See if it joins that way and then you can move it back to whatever vlan you had it in. Here is a good link on mesh troubeshooting with more debug commands:
http://www.cisco.com/en/US/docs/wireless/access_point/1500/troubleshooting/guide/TrbleshtMesh.html
06-05-2012 02:10 AM
Hi Scott,
I have tested on the same Vlan as the WLC, a completely new Vlan with DHCP scope, but still nothing. Herewith an extraction from the AP logs.
% CDP is not supported on this interface, or for this encapsulation
*Jun 5 05:38:06.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 10.23.255.129 peer_port: 5246
*Jun 5 05:38:06.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:38:06.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
peer_ip: 10.23.255.129 peer_port: 5246
*Jun 5 05:38:06.711: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:38:06.711: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:38:06.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:38:06.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:38:06.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:38:06.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:38:06.823: status of voice_diag_test from WLC is false
*Jun 5 05:38:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:38:17.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:38:17.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:38:17.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:38:17.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:38:17.719: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:38:17.719: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:38:17.719: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:38:17.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:38:17.827: status of voice_diag_test from WLC is false
*Jun 5 05:38:28.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:38:28.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:38:28.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:38:28.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:38:28.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:38:28.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:38:28.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:38:28.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:38:28.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:38:28.827: status of voice_diag_test from WLC is false
*Jun 5 05:38:38.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:38:38.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:38:38.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:38:38.711: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:38:38.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:38:38.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:38:38.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:38:38.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:38:38.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:38:38.823: status of voice_diag_test from WLC is false
*Jun 5 05:38:46.247: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Jun 5 05:38:46.247: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Jun 5 05:38:46.247: %MESH-6-LINK_UPDOWN: Mesh station 2c3f.38be.365c link Down
*Jun 5 05:38:49.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:38:49.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:38:55.619: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:38:55.619: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Jun 5 05:38:55.659: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:38:55.727: status of voice_diag_test from WLC is false
*Jun 5 05:39:06.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:39:06.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:39:06.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:39:06.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:39:06.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:39:06.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:39:06.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:39:06.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:39:06.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:39:06.823: status of voice_diag_test from WLC is false
*Jun 5 05:39:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:39:17.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:39:17.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:39:17.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:39:17.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:39:17.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:39:17.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:39:17.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:39:17.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:39:17.823: status of voice_diag_test from WLC is false
*Jun 5 05:39:28.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:39:28.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:39:28.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:39:28.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:39:28.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:39:28.719: %DTLS-5-ALERT: Received WARNING
% CDP is not supported on this interface, or for this encapsulation: Close notif
y alert from 10.23.255.129
*Jun 5 05:39:28.719: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:39:28.719: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:39:29.859: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:39:29.931: status of voice_diag_test from WLC is false
*Jun 5 05:39:40.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:39:40.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:39:40.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:39:40.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:39:40.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:39:40.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:39:40.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:39:40.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:39:40.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:39:40.823: status of voice_diag_test from WLC is false
*Jun 5 05:39:50.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:39:50.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:39:50.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:39:50.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:39:50.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:39:50.719: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:39:50.719: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:39:50.719: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:39:50.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:39:50.827: status of voice_diag_test from WLC is false
*Jun 5 05:40:01.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:40:01.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:40:01.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:40:01.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:40:01.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:40:01.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:40:01.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:40:01.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:40:01.751: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:40:01.823: status of voice_diag_test from WLC is false
*Jun 5 05:40:12.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:40:12.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:40:12.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:40:12.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:40:12.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:40:12.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:40:12.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:40:12.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:40:12.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:40:12.823: status of voice_diag_test from WLC is false
*Jun 5 05:40:23.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:40:23.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:40:23.719: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:40:23.719: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:40:23.719: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:40:23.719: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:40:23.719: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:40:23.723: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:40:23.759: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:40:23.827: status of voice_diag_test from WLC is false
*Jun 5 05:40:34.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:40:34.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:40:34.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:40:34.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:40:34.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:40:34.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:40:34.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:40:34.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:40:34.751: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:40:34.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:40:34.823: status of voice_diag_test from WLC is false
*Jun 5 05:40:45.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:40:45.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:40:45.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:40:45.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:40:45.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:40:45.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:40:45.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:40:45.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:40:45.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:40:45.823: status of voice_diag_test from WLC is false
*Jun 5 05:40:55.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:40:55.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:40:55.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:40:55.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:40:55.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:40:55.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:40:55.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:40:55.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:40:55.751: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:40:55.823: status of voice_diag_test from WLC is false
*Jun 5 05:41:06.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:41:06.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:41:06.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:41:06.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:41:06.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:41:06.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:41:06.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:41:06.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:41:06.751: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:41:06.823: status of voice_diag_test from WLC is false
*Jun 5 05:41:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:41:17.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:41:17.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:41:17.711: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:41:17.711: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:41:17.715: %DTLS-5-ALERT: Received WARNING
*Jun 5 05:41:17.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:41:17.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:41:18.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:41:18.827: status of voice_diag_test from WLC is false
*Jun 5 05:41:25.787: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Jun 5 05:41:25.787: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Jun 5 05:41:25.787: %MESH-6-LINK_UPDOWN: Mesh station 2c3f.38be.365c link Down
*Jun 5 05:41:29.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:41:29.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:41:34.995: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:41:34.995: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Jun 5 05:41:35.031: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:41:35.103: status of voice_diag_test from WLC is false
*Jun 5 05:41:45.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:41:45.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:41:45.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:41:45.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:41:45.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:41:45.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:41:45.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:41:45.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:41:45.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:41:45.827: status of voice_diag_test from WLC is false
*Jun 5 05:41:56.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:41:56.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:41:56.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:41:56.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:41:56.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:41:56.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:41:56.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:41:56.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:41:56.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:41:56.823: status of voice_diag_test from WLC is false
*Jun 5 05:42:07.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:42:07.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:42:07.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:42:07.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:42:07.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:42:07.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:42:07.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:42:07.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:42:07.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:42:07.823: status of voice_diag_test from WLC is false
*Jun 5 05:42:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:42:17.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:42:17.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:42:17.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:42:17.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:42:17.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:42:17.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:42:17.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:42:17.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:42:17.827: status of voice_diag_test from WLC is false
*Jun 5 05:42:28.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:42:28.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:42:28.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:42:28.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:42:28.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:42:28.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:42:28.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:42:28.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:42:28.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:42:28.827: status of voice_diag_test from WLC is false
*Jun 5 05:42:39.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:42:39.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:42:39.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:42:39.711: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:42:39.711: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:42:39.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:42:39.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:42:39.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:42:39.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:42:39.823: status of voice_diag_test from WLC is false
*Jun 5 05:42:50.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:42:50.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:42:50.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:42:50.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:42:50.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:42:50.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:42:50.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:42:50.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:42:50.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:42:50.823: status of voice_diag_test from WLC is false
*Jun 5 05:43:01.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:43:01.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:43:01.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:43:01.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:43:01.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:43:01.715: %DTLS-5-ALERT: Received WARNING
*Jun 5 05:43:01.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:43:01.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:43:01.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:43:02.831: status of voice_diag_test from WLC is false
*Jun 5 05:43:13.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:43:13.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:43:13.719: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:43:13.719: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:43:13.719: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:43:13.719: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:43:13.719: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:43:13.719: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:43:13.759: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:43:13.831: status of voice_diag_test from WLC is false
*Jun 5 05:43:23.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:43:23.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:43:23.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:43:23.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:43:23.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:43:23.715: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:43:23.715: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:43:23.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:43:23.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:43:23.827: status of voice_diag_test from WLC is false
*Jun 5 05:43:45.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 5 05:43:45.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jun 5 05:43:45.715: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 5 05:43:45.715: %CAPWAP-5-SENDJOIN: sending Join Request to 10.23.255.129
*Jun 5 05:43:45.715: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jun 5 05:43:45.719: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.23.255.129
*Jun 5 05:43:45.719: %DTLS-5-PEER_DISCONNECT: Peer 10.23.255.129 has closed con
nection.
*Jun 5 05:43:45.719: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
23.255.129:5246
*Jun 5 05:43:45.755: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jun 5 05:43:45.827: status of voice_diag_test from WLC is false
06-05-2012 09:25 AM
Here is the doc
'''snip'''
Features Not Supported on Mesh Networks
These controller features are not supported on mesh networks:
Multi-country support
Load-based CAC (Mesh networks support only bandwidth-based, or static, CAC.)
High availability (fast heartbeat and primary discovery join timer)
EAP-FASTv1 and 802.1X authentication
Locally significant certificate
Location-based services
'''snip'''
Reference:http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008072ea79.shtml#features
06-05-2012 09:16 AM
Using multiple country codes is not supported for mesh APs.
Try put use only one country for wlc regulatory.
I am not sure if your old aps and the new mesh are supported under same country but I hope they are.
Amjad
