AIR-CAP1552E: no L3 connection
Hello!
there is the problem with the new CAP1552
- it is connected to switch access port, where we can see its MAC address
- from cdp details we can also see its ip address
- dhcp server is configured on the router 2911, where we can see ARP and dhcp binding for the AP ip-address
All seems to be ok, but the AP is not reacheable by L3.
Ispite of this, from the controller log there are authentication failure messages with its ip-address
AAA Authentication Failure for UserName:<MAC>  User Type: WLAN USER
LED Signals:
Status blinking red/green, then blinks steady red
Uplink green
RF-1 green
RF-2 green
what can cause such kind of problem?
1 ACCEPTED SOLUTION
Re: AIR-CAP1552E: no L3 connection
You need the 1552 ti join the WLC. Make sure you have the Mac address if the ap in the macfilter.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Steve
thank you!
the problem is solved!
it was macfilter issue
653
