AIR-CAP1602E-N-K9 access point
hi,
can any one help me to configure AIR-CAP1602E-N-K9 as standalone acess point.
its a new one with default setting as per my knowledege its a controller based access point so pls help how to convert into standalone access point and which image is compatible with that.
2 ACCEPTED SOLUTIONS
Gold
Hi Kamal,Hope below links
Hi Kamal,
Hope below links will keep you started with LWAP to autonomous.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/docs/DOC-14960
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
For standalone AP you could use below configuration.In the below link you can ignore the configuration under "Bridge Configuration"
https://supportforums.cisco.com/document/61936/autonomous-ap-and-bridge-basic-configuration-template
Hope that helps.
Najaf
VIP Purple
HI Kamal,Yes you can convert
HI Kamal,
Yes you can convert it to Autonomous AP and then you can configure.
How to convert to Autonomous AP:
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
How to conifgure:
Multiple ssid: http://rscciew.wordpress.com/2014/05/24/multiple-ssid-configurations-on-autonomous-ap/
Single ssid: http://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-autonomous-ap/
Dont forget to rate helpful posts
Gold
Hi Kamal,
Hope that helps.
Najaf
thakns kcnajaf , i will try
thakns kcnajaf ,
i will try
VIP Purple
HI Kamal,
How to conifgure:
Converting a Lightweight
Converting a Lightweight Access Point Back to Autonomous Mode
You can convert an access point from lightweight mode back to autonomous mode by loading a Cisco IOS Release that supports autonomous mode (Cisco IOS release 12.3(7)JA or earlier). If the access point is associated to a controller, you can use the controller to load the Cisco IOS release. If the access point is not associated to a controller, you can load the Cisco IOS release using TFTP.
Note In some LWAPP deployments, the LWAPP controller resides between the access points and the rest of the network. In this topology, all traffic must cross over the controller before communication with network resources, such as a TFTP server, can occur. When converting back to non-LWAPP IOS with an access point that is no longer using the LWAPP protocol, traffic does not cross over the controller to reach the TFTP server.
Note The lightweight 1300 series access points can only be converted back to autonomous mode using a wireless LAN controller.
Using a Wireless LAN Controller to Return to a Previous Release
Follow these steps to revert from LWAPP mode to autonomous mode using a wireless LAN controller:
Step 1 Log into the CLI on the controller to which the access point is associated.
Step 2 Enter this command:
config ap tftp-downgrade tftp-server-ip-address filename access-point-name
Using a TFTP Server to Return to a Previous Release
Note This section does not apply to Cisco C3201WMIC and Cisco C3201LAP.
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Set the timeout value on the TFTP server to 30 seconds.
Step 4 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View; then uncheck the Hide extensions for known file types check box.
Step 5 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, c1240-k9w7-tar.default for a 1240 series access point, and c1250-k9w7-tar.default for a 1250 series access point.
Step 6 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 7 Disconnect power from the access point.
Step 8 Press and hold MODE while you reconnect power to the access point.
Step 9 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 10 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 11 After the access point reboots, reconfigure it using the GUI or the CLI.
1058
