AIR-CAP1602I-N-K9
i have 5500 series wlc and i have more then 100 lap which is connected to wlc,all lap having static ip to different different vlan ok then problem is that when any lap down due to power off then lap pick ip from dhcp (actully i have make different dhcp server to different vlan) server which is run to main switch, so i was go to wlc and reset ap so its working on static ip but some time when lap restart then lap(lap means light wait access point 1600 series) showing 3 diffrant colour light (rad ,amber green) and not provind any service and in same time lap is not showing in wlc so kindly look on that matter and suggest me...........
Hall of Fame Super Gold
Do you have DHCP Option 43
Do you have DHCP Option 43 enabled?
no dhcp option 43 enabled
no dhcp 43 enabled
no dhcp 43 enabled
 Please enable your option 43
Please enable your option 43 for DHCP. The it will definitely work.
287
