AIR-CAP2602 will not register with 5508WLC
I setup this controller a month or two ago and have joined several AIP-CAP2602I-A-K9 AP's to it. I went to add a few more and they will not register. Here is the data from the console of the AP.
Mar  1 00:00:13.047: %CDP_PD-2-POWER_LOW: All radios disabled - AC_ADAPTOR  (0000.0000.0000)
*Mar  1 00:00:13.579: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:15.447: DPAA Initialization Complete
*Mar  1 00:00:15.447: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:15.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
no bridge-group 1 source-learning
% Invalid input detected at '^' marker.
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:46.563: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.1.8.58, mask 255.255.0.0, hostname APe02f.6da3.6037
Translating "CISCO-CAPWAP-CONTROLLER.JSMC.ORG"...domain server (10.1.0.20)
*Mar  1 00:00:57.539: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:00.539: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.JSMC.OR
*Jul 25 13:36:54.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.7.47 peer_port: 5246
*Jul 25 13:36:56.443: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.7.47 peer_port: 5246
*Jul 25 13:36:56.447: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.7.47
*Jul 25 13:37:01.447: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.7.47
*Jul 25 13:37:01.447: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.7.47
*Jul 25 13:37:01.447: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.7.47:5246
*Jul 25 13:37:01.447: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 25 13:36:54.447: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.7.47 peer_port: 5246
*Jul 25 13:36:54.447: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.7.47
logging facility kern
logging trap emergencies
*Jul 25 13:36:59.447: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.7.47
*Jul 25 13:36:59.447: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.7.47
*Jul 25 13:36:59.447: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.7.47:5246
*Jul 25 13:36:59.447: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 25
*Jul 25 13:37:09.807: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 25 13:37:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.7.47 peer_port: 5246
*Jul 25 13:37:17.443: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.7.47 peer_port: 5246
*Jul 25 13:37:17.443: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.7.47
*Jul 25 13:37:22.443: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.7.47
*Jul 25 13:37:22.443: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.7.47
*Jul 25 13:37:22.443: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.7.47:5246
*Jul 25 13:37:22.443: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 25 13:37:17.447: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.7.47 peer_port: 5246
*Jul 25 13:37:17.447: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.7.47
*Jul 25 13:37:22.447: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.7.47
*Jul 25 13:37:22.447: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.7.47
*Jul 25 13:37:22.447: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.7.47:5246
*Jul 25 13:37:22.447: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
Any help would be greatly appreciated. Thanks in advance
Everyone's tags (2)
1 ACCEPTED SOLUTION
Bronze
Re: AIR-CAP2602 will not register with 5508WLC
can you get debug capwap event and debug capwap error as well on wlc
Bronze
Debug capwap event log:
*spamApTask6: Jul 25 12:02:06.487: e0:2f:6d:a3:60:30  Join request received from AP which is already present. Deleting  previous  connection        10.1.8.58:13828
*spamApTask6: Jul 25 12:02:06.487: e0:2f:6d:a3:60:30 Finding DTLS connection to delete for AP (10:1:8:58/13828)
*spamApTask6: Jul 25 12:02:06.487: e0:2f:6d:a3:60:30 Disconnecting DTLS Capwap-Ctrl session 0x146ee4d8 for AP (10:1:8:58/13828)
*spamApTask6: Jul 25 12:02:06.487: e0:2f:6d:a3:60:30 CAPWAP State: Dtls tear down
*spamApTask6: Jul 25 12:02:06.488: e0:2f:6d:a3:60:30 DTLS keys for Control Plane deleted successfully for AP 10.1.8.58
*spamApTask6: Jul 25 12:02:06.489: e0:2f:6d:a3:60:30 DTLS connection not found. Ignoring join request from 10.1.8.58:13828
*spamApTask6: Jul 25 12:02:06.489: e0:2f:6d:a3:60:30 DTLS  connection closed event receivedserver (10:1:7:47/5246) client  (10:1:8:58/13828)
*spamApTask6: Jul 25 12:02:06.489: e0:2f:6d:a3:60:30 No entry exists for AP (10:1:8:58/13828)
*spamApTask6: Jul 25 12:02:06.489: e0:2f:6d:a3:60:30 No AP entry exist in temporary database for 10.1.8.58:13828
*spamApTask6: Jul 25 12:02:06.849: e0:2f:6d:a3:60:30 Discovery Request from 10.1.8.58:13828
*spamApTask6: Jul 25 12:02:06.849: e0:2f:6d:a3:60:30 Join  Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 25,  joined Aps =4
*spamApTask6: Jul 25 12:02:06.849: e0:2f:6d:a3:60:30 Discovery Response sent to 10.1.8.58:13828
*spamApTask6: Jul 25 12:02:06.850: e0:2f:6d:a3:60:30 Discovery Request from 10.1.8.58:13828
*spamApTask6: Jul 25 12:02:06.850: e0:2f:6d:a3:60:30 Join  Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 25,  joined Aps =4
*spamApTask6: Jul 25 12:02:06.850: e0:2f:6d:a3:60:30 Discovery Response sent to 10.1.8.58:13828
*spamApTask4: Jul 25 12:02:09.661: 04:da:d2:4e:93:e0 WTP Event Request from 10.1.8.55:7061
*spamApTask4: Jul 25 12:02:09.661: 04:da:d2:4e:93:e0 WTP Event Response sent to 10.1.8.55:7061
*spamApTask3: Jul 25 12:02:15.409: 24:01:c7:c1:e2:00 WTP Event Request from 10.1.8.56:13827
*spamApTask3: Jul 25 12:02:15.409: 24:01:c7:c1:e2:00 WTP Event Response sent to 10.1.8.56:13827
*spamApTask6: Jul 25 12:02:16.847: e0:2f:6d:a3:60:30 DTLS  connection not found, creating new connection for 10:1:8:58 (13828)  10:1:7:47 (5246)
*spamApTask6: Jul 25 12:02:17.295: e0:2f:6d:a3:60:30 Allocated index from main list, Index: 114
*spamApTask6: Jul 25 12:02:17.295: e0:2f:6d:a3:60:30 DTLS keys  for Control Plane are plumbed successfully for AP 10.1.8.58. Index 115
*spamApTask6: Jul 25 12:02:17.295: e0:2f:6d:a3:60:30 DTLS Session established server (10.1.7.47:5246), client (10.1.8.58:13828)
*spamApTask6: Jul 25 12:02:17.295: e0:2f:6d:a3:60:30 Starting wait join timer for AP: 10.1.8.58:13828
*spamApTask6: Jul 25 12:02:17.297: e0:2f:6d:a3:60:30 Join Request from 10.1.8.58:13828
*spamApTask6: Jul 25 12:02:17.298: e0:2f:6d:a3:60:30 Deleting AP entry 10.1.8.58:13828 from temporary database.
*spamApTask6: Jul 25 12:02:17.298: e0:2f:6d:a3:60:30 MIC AP is not allowed to join by config
*spamReceiveTask: Jul 25 12:02:20.053: 04:da:d2:4e:93:e0 Configuration update request for delete station sent to 10.1.8.55:7061
*spamApTask4: Jul 25 12:02:20.054: 04:da:d2:4e:93:e0 Configuration Update Response from 10.1.8.55:7061
*spamApTask4: Jul 25 12:02:20.055: 04:da:d2:4e:93:e0 Configuration Update Response from 10.1.8.55:7061
*spamApTask4: Jul 25 12:02:20.403: 24:01:c7:f7:2e:60 Echo Request from 10.1.8.70:60150
*spamApTask4: Jul 25 12:02:20.403: 24:01:c7:f7:2e:60 Echo Response sent to 10.1.8.70:60150
*spamApTask6: Jul 25 12:02:22.296: e0:2f:6d:a3:60:30 Join Request from 10.1.8.58:1382
Capwap Error:
*spamApTask6: Jul 25 12:06:37.352: e0:2f:6d:a3:60:30 Multiple Join Request: Join request received from AP which is already present. Deleting previous conne
*spamApTask6: Jul 25 12:06:37.354: e0:2f:6d:a3:60:30 State machine handler: Failed to process  msg type = 3 state = 0 from 10.1.8.58:13828
*spamApTask6: Jul 25 12:06:37.354: e0:2f:6d:a3:60:30 Failed to parse CAPWAP packet from 10.1.8.58:13828
*spamApTask6: Jul 25 12:06:37.354: e0:2f:6d:a3:60:30 Discarding non-ClientHello Handshake OR DTLS encrypted packet from  10.1.8.58:13828)since DTLS session is not established
*spamApTask6: Jul 25 12:06:37.806: e0:2f:6d:a3:60:30 State machine handler: Failed to process  msg type = 3 state = 0 from 10.1.8.58:13828
*spamApTask6: Jul 25 12:06:37.806: e0:2f:6d:a3:60:30 Failed to parse CAPWAP packet from 10.1.8.58:13828
I resolved it. I noticed in the CAPWAP event log where it says "MIC AP is not allowed to join by config". I told the controller to accept Manufactured Installed Certificate (MIC) and they are registering now. Thanks for the help
1141
