AIR-CAP2602E-A-K9 not joining the WLC
I have approximately 20 of these AP's and 9 of them joined the WLC successfull.  However remaining 11 that are connected to another switch are not joining the WLC.  They are not getting the IP and on the router I don't even see any DHCP requests from them.
There are no ACL's on the switch, it is configured the same way as the other switch with working AP's.  Here is the difference I am seeing though when I do show cdp ne de:
Looks like the ones that are not working have a different image I guess that is because they never joined the controller and updated.  Any ideas?
Working AP's:
Device ID: APf872.ea23.d9ef
Entry address(es):
  IP address: 10.137.136.49
Platform: cisco AIR-CAP2602E-A-K9   ,  Capabilities: Router Trans-Bridge
Interface: FastEthernet0/6,  Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 136 sec
Version :
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Version 15.2(2)JB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 29-Jul-13 11:27 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 15.400 Watts
Power request id: 11555, Power management id: 3
Power request levels are:15400 0 0 0 0
Management address(es):
Non Working AP's:
Device ID: AP4c00.82cb.e693
Entry address(es):
Interface: FastEthernet0/8,  Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 162 sec
Version :
Cisco IOS Software, C2600 Software (AP3G2-RCVK9W8-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 00:07 by prod_rel_team
Duplex: full
Power drawn: 13.000 Watts
Power request id: 64041, Power management id: 2
Power request levels are:13000 0 0 0 0
  • Getting Started with Wireless
I found this would this be an issue with 2602's I wonder?
https://supportforums.cisco.com/thread/2202895
Resolved.
How did you resolve? I see that the AP not working didn't receive sufficient power - was that part of the issue? Or did you resolve through the thread that you linked?
VIP Purple
HI peter,
Symptom:
A lightweight IOS AP may be unable to join a controller.
Conditions:
AP is a 3600 series, with the 12.4(25e)JAL1 recovery IOS image (rcvk9w8)
installed on it.  This image may be factory installed on APs manufactured
in the first half of CY 2013.
The AP's default gateway is configured not to perform proxy ARP.
Workaround:
1. Make sure that ip proxy-arp is configured (default setting for an IOS
router),  on the AP's subnet's default gateway. Also if ip broadcast-address is  defined on the vlan with something other than 255.255.255.255 the AP  will not join. Either no this command or set it to broadcast.
2. If console access is available on the AP, then disable IP routing - then it
should be able to join, and download the new IOS image:
ap#debug capwap console cli
ap#configure terminal
ap(config)#no ip routing
(wait for it to join)
This setting will not survive a reboot.
3. Install a different recovery (rcvk9w8) or lightweight IOS (k9w8) image on
the AP, such as 15.2(2)JA1.
More information:
The 12.4(25e)JAL1 recovery image installs two default routes in the AP's
routing table: one to the default gateway, and the other to the interface.
The latter route works only if proxy ARP is enabled on the gateway.  As a
result, without proxy ARP, every other IP packet transmitted by the AP
is dropped.
For more information on this issue, see the following CSC article:
New 3600 Series Access Points Cannot Join a WLC
https://supportforums.cisco.com/docs/DOC-30836
Hi Sandeep
Thanks for replying, but I have already read that in the bug ID.
My question was if Muhammad resolved his issue by reading that or he found another way, because I have a problem where my APs don't get IP addresses - they are only receiving 13W from the PoE switch, but on my other switches I see that they receive 15,4W - and that's what I saw in Muhammads initially post.
It is strange, because I just replaced the switch with another one that I tested with one AP - and that worked and received 15,4 W - but now they only receive 13W again and don't get IP addresses...
VIP Purple
Re: AIR-CAP2602E-A-K9 not joining the WLC
Means your switch couldn't provide enough power supply to AP.
No it's not that, same AP same switch, only one AP does the same thing - 13W. CDP info:
Same AP other switch, same thing.
I tested the switch back home with another AP and it got 15,4W and CDP info:
Power request levels are:15400 13000 0 0 0
it actually looks like those AP have MESH code on them for some reason.
add the MAC address of one of the AP that is not joining to the macfilter on the WLC to see if that resolves the issue.  If it does, then add the rest and change the mode to local from bridge.
If it doesn't, please post back and let us know.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hi Steve
Thanks for your reply.
I will try your suggestions out today and post back.
1039
