AIR-CAP2602I-R-K9 doesn't start
Hello, everybody!
Wrong hands broke one of my snowy APs...=( I've no idea what actually was done, but the startup process stops like this...
ap: boot
Loading "flash:/ap3g2-k9w8-mx.152-2.JB/ap3g2-k9w8-xx.152-2.JB"...uncompress: Unknown mzip segment type: 2
Error loading "flash:/ap3g2-k9w8-mx.152-2.JB/ap3g2-k9w8-xx.152-2.JB"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
ap:
I still have serial connection to AP... Will the deletion of ap3g2-k9w8-mx.152-2.JB file help me?
How can I reset AP to factory defaults?
Many thanks in advance...
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
You need to be able to boot into an image....  Here are some instructions for ROMMOM
https://supportforums.cisco.com/thread/2043235
Can you issue a dir when in the ap: prompt and post that info.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
VIP Purple
Re: AIR-CAP2602I-R-K9 doesn't start
Unplug the AP then hold in the mode button (use a paper clip or pen tip). While still holding the button down plug the device back in and wait for the light(s) to go steady red. If your AP has a console port you should be good to go
Check these links":
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/9215-pwrec-2.html#resios
Dont forget to rate helpful posts
VIP Purple
may be this IOS is corrupt, then you have to reload it.
Here is the process:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4_10b_JA/configuration/guide/scg12410b/scg12410b-chap22-trouble.html#wp1038660
Regards]Dont forget to rate helpful posts
Scott
-Scott
Many thanks to you, guys, especially to Scott! =)
Glad you got it working.
From the ROMMON, you can boot from
Various images also which helps if you have multiple images and maybe for testing or converting.
-Scott
754
