AIR-CT2504-15-K9
I need a wireless AP list compatible with AIR-CT2504-15-K9!
Thanks!
  • Getting Started with Wireless
Gold
Here is a matrix that tells
Here is a matrix that tells you what code is supported on what platform.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
The AIR-CT2504-15-K9 can handle up to 15 Accesspoints.
Bronze
Hello, Alex. Check out
Hello, Alex.
Check out mohanak's compatibility matrix link to identify compatible AP's on certain WLC version release. Do you have existing older Cisco access points that you are planning to use?
Kind regards.
Bronze
Please find the attached pdf
Please find the attached pdf file listing all the compatible APs.
80
