04-08-2014 03:06 AM - edited 07-05-2021 12:38 AM
Currently i am using AIR-CT5508-100-K9 in my company and now we are planning to go for HA mode, can i go with AIR-CT5508-12-K9 or i need to order a unit with minimum of 50 licenses.
04-16-2014 03:29 AM
If you can order AIR-CT5508-HA-K9, if no more support to AP is needed. When the active controller is unavailable, the standby controller will adopt the licenses from the primary controller.
12-17-2014 01:30 AM
You need to either purchase an HA SKU controller or convert a 5508 to secondary but you need at least 50 valid licenses for that, which means that you cannot convert a 12 license controller.
Simone
01-08-2015 02:02 AM
Adding to the others solution refer the link : http://www.cisco.com/c/en/us/td/docs/wireless/technology/hi_avail/N1_High_Availability_Deployment_Guide/Licensing.html
