AIR-CT5508-100-K9 in HA
Currently i am using AIR-CT5508-100-K9 in my company and now we are planning  to go for HA mode, can i go with AIR-CT5508-12-K9 or i need to order a unit with minimum of 50 licenses.
If you can order AIR-CT5508
If you can order AIR-CT5508-HA-K9, if no more support to AP is needed. When the active controller is unavailable, the standby controller will adopt the licenses from the primary controller.
You need to either purchase
You need to either purchase an HA SKU controller or convert a 5508 to secondary but you need at least 50 valid licenses for that, which means that you cannot convert a 12 license controller.
Simone
Adding to the others solution
374
