AIR-CT5760-100-K9
Hi, We have configured 802.11ac for 5GHz Antenna but we do not have any client which supports 802.11ac for now. We have only windows7 PC which supports only 802.11b/g/n. Please let me know how do i test 802.11ac and confirm if it is working. Is it possible to test it with any third party plugin which can be installed on Win machine and test it?
MAC
Regards MAC
Everyone's tags (3)
3 ACCEPTED SOLUTIONS
VIP Purple
AIR-CT5760-100-K9
There are few clients if you find any (Nexus 5 phone, Samsung S4 phone, Macbook Air, Macbook Pro).
What AP models do you have (3700 or 3600 with ac module). You should run IOS-XE 3.3.1 for the 3700. Here is some ac test perfromance with 5508 & WLC 7.6 code in my environment.
http://mrncciew.com/2014/01/10/802-11ac-with-cisco-3700-ap/
Here is some 5760 configurations which may be useful to you
1. http://mrncciew.com/2013/12/12/getting-started-with-5760/
2. http://mrncciew.com/2013/12/16/5760-in-ca-cuwn/
Rasika
**** Pls rate all useful resposnes ****
VIP Purple
Re: AIR-CT5760-100-K9
Hi MAC,
Then you have to get a USB wireless adapter that will support 11ac. You should be able to find different products in the market
Here is one product (I haven't test it myself, but should work)
http://support.linksys.com/en-apac/support/adapters/AE6000
On your 5760 802.11a/n/ac band you have to set the channel-width to 80MHz to support 11ac. Here is the CLI commands to do that.
WLC5760(config)#ap dot11 5ghz shut
WLC5760(config)#ap dot11 5ghz rrm channel dca chan-width 80
WLC5760(config)#no ap dot11 5ghz shut
Once you do this, you can issue the following command to see the what channel AP assigned. You should see 4 channels assigned to 802.11ac support APs in your network
WLC5760#show ap dot11 5ghz summary
Rasika
*** Pls rate all useful responses ****
VIP Purple
AIR-CT5760-100-K9
That's great...
yes samsung S4 is single spacial stream device & you can get max of 433Mbps. If you got 390Mbps real throughput that is excellent.
If you want higher througput your client should support 3 Spacial stream (Macbook Pro support 3SS) & therotical max of 1.3Gbps (but will be limited to 1Gbps because of 1G port of AP & your switchport)
Macbook air support 2 SS & you can get 867Mbps max.
In practical terms if you get more than 50% of the max value that is really good as multiple clients share the given AP bandwidth at a time.
Pls do not forget to rate our responses if that useful to you
Rasika
VIP Purple
AIR-CT5760-100-K9
Rasika
AIR-CT5760-100-K9
Hi Rasika,
Thank you for providing all the details, could you please tell me how do i test 802.11ac? I have only windows 7 PC which supports 802.11b/g/n and do not support 802.11ac.
MAC
Regards MAC
VIP Purple
Hi MAC,
Rasika
AIR-CT5760-100-K9
Hi, Thanks Rasika i am finally able to get connected to 802.11ac. But i am getting the speed 390MBps only. Will there be any limitations on the client side? i am using Samsung S4 Mobile which supports 802.11ac
Thanks in advance
MAC
Regards MAC
VIP Purple
AIR-CT5760-100-K9
That's great...
Rasika
AIR-CT5760-100-K9
Hi Rasika,
This information is very useful. I got to know that Linksys wireless Mini USB Dual Band is not available in India.
Will there be any other adaptors which i can purchase which full fill my requirement?
MAC
Regards MAC
VIP Purple
AIR-CT5760-100-K9
You can try to find in bigger cities like Delhi or Bangalore(chor bazar ..just kidding ):
http://www.netgear.com/home/products/networking/wifi-adapters/a6200.aspx
You can also buy from Aamazon:
http://www.amazon.de/Linksys-AE6000-Mini-Wireless-AC-Adapter/dp/B00B9Q3EE8
VIP Purple
AIR-CT5760-100-K9
Hi MAC,
Here is a very useful link which inclue all 802.11ac products currently available in the market. If you check the "Adapter" section of this document you will find all the USB adapters which support 802.11ac.
http://wikidevi.com/wiki/List_of_802.11ac_Hardware
When purchasing USB card, make sure it is supporting all the 5GHz frequency channels (some of them are not supporting UNII-3 CH149 to CH161), so you may have limited since then cannot assoicate a AP operate on this band.
Rasika
**** Pls rate all useful responses ****
359
