AIR LAP 1142N
  I am having one AIR LAP 1142N, I want to make this AP as standalone but I am not able to go in configure terminal command and I am not getting BVI interface too in
show ip int brief
I am sending my Access Point running configuration
APa493.4c52.a91f#sh run
Building configuration...
Current configuration : 16735 bytes
version 12.4
no service pad
hostname APa493.4c52.a91f
enable secret 5 $1$XhAv$99uKdgB4Jo.dhS1TKchY//
crypto pki trustpoint Cisco_IOS_MIC_cert
revocation-check none
rsakeypair Cisco_IOS_MIC_Keys
crypto pki trustpoint cisco-root-cert
crypto pki trustpoint airespace-device-root-cert
crypto pki trustpoint airespace-new-root-cert
crypto pki trustpoint airespace-old-root-cert
crypto pki certificate chain Cisco_IOS_MIC_cert
certificate 2333A54B000000080D96
  30820470 30820358 A0030201 02020A23 33A54B00 0000080D 96300D06 092A8648
  86F70D01 01050500 30393116 30140603 55040A13 0D436973 636F2053 79737465
  6D73311F 301D0603 55040313 16436973 636F204D 616E7566 61637475 72696E67
  20434130 1E170D31 32303531 34323034 3035325A 170D3232 30353134 32303530
  35325A30 818C310B 30090603 55040613 02555331 13301106 03550408 130A4361
  6C69666F 726E6961 3111300F 06035504 07130853 616E204A 6F736531 16301406
  0355040A 130D4369 73636F20 53797374 656D7331 1B301906 03550403 13124331
  3134302D 61343933 34633532 61393166 3120301E 06092A86 4886F70D 01090116
  11737570 706F7274 40636973 636F2E63 6F6D3082 0122300D 06092A86 4886F70D
username Cisco secret 5 $1$Jug8$lzs5T1AoQfo8e3tXN05uy/
interface GigabitEthernet0
ip address dhcp client-id GigabitEthernet0
no ip route-cache
duplex auto
speed auto
no keepalive
line con 0
line vty 0 4
login
end
APa493.4c52.a91f#
APa493.4c52.a91f#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0           unassigned      YES other  up                    down
APa493.4c52.a91f#
*Mar  1 00:20:44.944: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
And I am getting this error message
Shoud I need to reset the AP completely, need help.
1 ACCEPTED SOLUTION
VIP Purple
AIR LAP 1142N
You can go into config mode of a LAP using "debug capwap console cli" command as shown below
3600-1#debug capwap console cli
This command is meant only for debugging/troubleshooting
Any configuration change may result in different
behavior from centralized configuration.
CAPWAP console CLI allow/disallow debugging is on
3600-1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
3600-1(config)#
Below should help you to do the LAP to IOS conversion
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Rasika
*** Pls rate all useful responses ***
VIP Purple
AIR LAP 1142N
3600-1#conf t
3600-1(config)#
Rasika
AIR LAP 1142N
Thanks a lot I dowloaded the IOS and my AP is working now as normal Access Point.
But I dotradio is not getting up when I am trying to connect in my network.
Please find below the running configuration and sh ip int bri
sh run:
version 12.4
no service pad
hostname AP
logging rate-limit console 9
enable secret 5 $1$iMEv$1KCsrQQDv4lxg1ZM3SRzb.
no aaa new-model
dot11 syslog
dot11 ssid Branch
   authentication open
   guest-mode
dot11 network-map
username Cisco secret 5 $1$8Xe/$mOIKjO39jQN4zfhDn0K5f0
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 ABCDEF123456 transmit-key
encryption mode wep mandatory
ssid Branch
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Branch
speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-36.0 basic-54.0
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 10.100.58.9 255.255.255.0
no ip route-cache
ip default-gateway 10.100.58.253
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
password cisco
login
line vty 0 4
password cisco
login
end
AP#
sh ip int bri:
BVI1                       10.100.58.9     YES manual up                    up
Dot11Radio0                unassigned      YES TFTP   initializing          down
Dot11Radio1                unassigned      YES NVRAM  initializing          down
GigabitEthernet0           unassigned      YES NVRAM  up                    up
showing me this error
*Mar  1 00:27:22.868: Interface Dot11Radio1: not starting because stop-on-failure set
*Mar  1 00:27:22.868: Interface Dot11Radio0: not starting because stop-on-failure set
Hall of Fame Super Silver
Re: AIR LAP 1142N
Console into the AP, Do a write men and reboot. Then post the output.
-Scott
417
