Community Member
AIR-LAP1131G not connecting to WLC4402-12
I am trying to configure the ATR-LAP1131G to WLC4402-12, i am getting invalid regularity domain and country code, LAP is new one , for WLC4402-12 already 10 APs are configured and connected. they are working fine. but when i am trying to connect the LAP1131G .i am getting these messages in the controler and AP
Jan 13 16:53:26.201 1x_auth_pae.c:2470 DOT1X-1-MAX_EAP_IE_RETRIES_REACHED: Reached Max EAP-Identity Request retries (21)
for STA00:1c:b3:7a:d6:da
Jan 13 16:53:22.703: [ERROR] spam_lrad.c 1891: AP 00:21:a0:f8:dc:00 not allowed to join. Regulatory Domain check complet
ely FAILED.
           Allowed: (802.11bg:-AN    802.11a:-N)
Jan 13 16:53:22.703: Previous message occurred 3 times.
Jan 13 16:53:22.703: [ERROR] spam_lrad.c 6715: AP 00:21:a0:f8:dc:00: Invalid country code ().
Jan 13 16:53:14.477: [ERROR] spam_lrad.c 1891: AP 00:21:a0:e3:c6:30 not allowed to join. Regulatory Domain check complet
ely FAILED.
AP error message
*Mar  1 00:00:05.398: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:06.798: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:07.936: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(3g)JA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 10-Aug-07 20:44 by kehsiao
*Mar  1 00:00:07.936: %SNMP-5-COLDSTART: SNMP agent on host AP0023.04b7.8880 is undergoing a cold start
*Mar  1 00:00:07.955: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:08.826: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:09.826: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:26.953: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:26.953: bsnInitRcbSlot: slot 1 has NO radio
*Mar  1 00:00:26.971: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Mar  1 00:00:29.421: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:29.459: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:30.422: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Translating "CISCO-LWAPP-CONTROLLER.technicolor.com"...domain server (10.17.36.22)
*Mar  1 00:00:36.294: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.17.36.214, mask 255.255.255.0, hostname AP0023.04b7.8880
*Mar  1 00:00:38.433: LWAPP_CLIENT_ERROR: lwapp_name_lookup - Could Not resolve CISCO-LWAPP-CONTROLLER.technicolor.com
*Mar  1 00:00:48.441: LWAPP_CLIENT_ERROR_DEBUG: spamHandleDiscoveryTimer : Found the discovery response from MASTER Mwar
*Mar  1 00:00:48.452: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar  1 00:00:48.453: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:49.453: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec 13 12:58:41.283: %LWAPP-5-CHANGED: LWAPP changed state to CFG
*Dec 13 12:58:46.283: LWAPP_CLIENT_ERROR_DEBUG: spamHandleCfgReqTimer: Did not recieve the Config response
*Dec 13 12:58:46.386: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET CONFIG RESPONSE.
and the AP will reboot
please help me
Javahar R.S.
Hall of Fame Super Silver
Is the country code correct?  What is the model of your AP and what country do you have set in the WLC?
-Scott
On the WLC CLI you can issue:
show country
-Scott
Your AP is in the M regulatory domain, and a/n radio is not supported in M domain . Your WLC is having a country code which support the a/b radio
Either you will have to change the country code in AP or in the WLC
NikhiL
Community Member
HI Scott
Country code in the WLC is IN, AP is zero configuration
Look at the model/part number on the AP.  There should be a label on the underside of the AP.  That model has to match the country your putting the AP in.
-Scott
Re: AIR-LAP1131G not connecting to WLC4402-12
The part number should be ex. AIR-LAP1142N-N-K9
You can reference: http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/product_data_sheet0900aecd80537b6a_ps6087_Products_Data_Sheet.html
-Scott
So you need to add KW to the country code list on the WLC.
On the CLI: config country KW
-Scott
Community Member
AP details :
cisco AIR-LAP1131G-A-K9    (PowerPCElvis) processor with 24566K/8192K bytes of memory.
Processor board ID FTX1353N0G5
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 4.1.185.0
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:23:33:BC:31:74
Part Number                          : 73-11587-02
PCA Assembly Number                  : 800-30422-01
PCA Revision Number                  : B0
PCB Serial Number                    : FOC12473F8Z
Top Assembly Part Number             : 800-29582-02
Top Assembly Serial Number           : FTX1353N0G5
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131G-A-K9
WLC Detials :
---------------Show sysinfo---------------
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 4.1.185.0
RTOS Version..................................... 4.1.185.0
Bootloader Version............................... 3.2.202.0
Build Type....................................... DATA + WPS
System Name...................................... WLC4402-12
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 10.17.36.8
System Up Time................................... 354 days 10 hrs 9 mins 18 secs
Configured Country............................... IN  - India
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +41 C
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 2
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 39
Burned-in MAC Address............................ 00:0B:85:43:04:E0
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
---------------Show Interface ---------------
Interface Configuration
Interface Name................................... ap-manager
MAC Address...................................... 00:0b:85:43:04:e7
IP Address....................................... 10.17.36.9
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.17.36.1
VLAN............................................. 36
--More-- or (q)uit
Active Physical Port............................. LAG (29)
Primary Physical Port............................ LAG (29)
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.17.36.22
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Interface Name................................... guest_wireless
IP Address....................................... 1XX.11.250.30
IP Netmask....................................... 255.255.255.224
IP Gateway....................................... 1XX.11.250.5
VLAN............................................. 250
Quarantine-vlan.................................. no
Primary DHCP Server.............................. Unconfigured
AP Manager....................................... No
Interface Name................................... management
MAC Address...................................... 00:0b:85:43:04:e0
Interface Name................................... service-port
MAC Address...................................... 00:0b:85:43:04:e1
IP Address....................................... 0.0.0.0
DHCP Protocol.................................... Enabled
--More-- or (q)uit
Interface Name................................... tms-wlan1
IP Address....................................... 10.17.37.4
IP Gateway....................................... 10.17.37.1
VLAN............................................. 37
Secondary DHCP Server............................ 10.17.36.22
Interface Name................................... virtual
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
Oh... thats a US access point, so you need to add US to the WLC: config country US
Is it going to be installed in the US?  You really need to make sure so you don't get in trouble or have the military knock on your door.  If you have the wrong AP, talk with your Cisco vendor and have them get you the correct AP.
-Scott
Is this same AP that you have put in the AP error message, as that says
Community Member
HI scott
can i change the country code US in the WLC, once the  device associate can i change the country code in the AP and WLC. if i  do this way .. will it efect to the network . the WLC wsa purchased 2-3  years back , by default the country code was US and we changed to IN at  the config time.  can i try
regards
Javahar R.S.
when you enable a country code you have to disable the A and B networks first then add te country and renewable them. But since the AP is for A you need make sure that you can use the ap in India without violating their regulatory domain.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
You will not be able to change the country code of the ap since it is manufactured for a specific country. You will have to purchase a new ap.
Scott Fella
Sent from my iPhone
-Scott
776
