AIR-LAP1141N-E-K9 Radio Interface Reset
I am facing a problem with my access point AIR-LAP1141N-E-K9, which was converted from LWAPP to autonomous, radio Interface Dot11Radio0 is going to reset down state very frequently.
I have to reboot every time to fix the problem. AP is connected to WS-C3560G-24PS (POE) switch.
Below is the AP configuration
SNC-Cisco-AP#sh run
Building configuration...
Current configuration : 1317 bytes
version 12.4
no service pad
service password-encryption
hostname SNC-Cisco-AP
no aaa new-model
dot11 syslog
dot11 ssid WIRELESS
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 0812424D3A00160317065D52
username sncsystem privilege 15 password 7 1521050F373338302D3E6474
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid WIRELESS
antenna gain 0
power local 14
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
ip http authentication local
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
CDP neighbour output from switch
Device ID: SNC-Cisco-AP
Entry address(es):
  IP address: 10.10.60.151
Platform: cisco AIR-LAP1141N-E-K9   ,  Capabilities: Trans-Bridge IGMP
Interface: GigabitEthernet0/18,  Port ID (outgoing port): GigabitEthernet0
Holdtime : 157 sec
Version :
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 10:20 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 15.000 Watts
Power request id: 56300, Power management id: 3
Power request levels are:15000 14500 0 0 0
Jamal
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: AIR-LAP1141N-E-K9 Radio Interface Reset
I would just try a different software version if the radios stay up for a while and then just goes in a status of reset.
-Scott
Salam Jamal,
Anything appears in the logs when the radio reset happens?
Your current IOS version is one of the oldest versions. I agree with Scott suggesting the upgrade. Try latest version 12.4.23c-JA5(ED) and hope that will fix most of your issues.
Amjad
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
Rating useful replies is more useful than saying "Thank you"
-Scott
Salam Jamal,
Amjad
Thanks Scott and Amjad..
I upgraded IOS to c1140-k9w7-mx.152-2.JA that fixed teh problem.
Great news.
2484
