Community Member
AIR LAP1142N DHCP Issue
Hi All,
We have an  autonomous AIR-LAP1142N-E-K9 AP with software release version 12.4(25d)JA1.
The access point is configured and an SSID is broadcasted. However when users are trying to connect to the AP, authentication seems to be accepted but users are not connected. I suspected the issue in DHCP but even on static IP the user is not connected.
I dont believe any LAN issue is there cause I connected a PC to the same interface where the AP is connected and it took an IP from the required VLAN (1234)
Config Below
Building configuration...
Current configuration : 4096 bytes
version 12.4
no service pad
service password-encryption
hostname AP
logging rate-limit console 9
enable secret 5 $1$OFqX$0AQEOwhX6umUJGjeg9BYW0
no aaa new-model
dot11 syslog
dot11 ssid WIRELESS
   vlan 1234
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 044809015E731F1A5C4F
crypto pki trustpoint TP-self-signed-4079972194
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4079972194
revocation-check none
rsakeypair TP-self-signed-4079972194
crypto pki certificate chain TP-self-signed-4079972194
certificate self-signed 01
  3082023A 308201A3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34303739 39373231 3934301E 170D3032 30333031 30303133
  31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30373939
  37323139 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D396 EE65F06D 87E10642 280B0742 AC9CCFF9 AC242C94 4DF146CC 5F3EA127
  7800A3BD D93343E2 BB5999C8 D2576298 33BC5787 3E26B5CF CC9048D2 DB3F4F5F
  FED7EC3C 5CC3DD7E 236ABBA2 D7D88AF9 F9732062 D1A2A92F 9448403D A9064900
  C728D700 FAF634E2 58DA1B58 D8B65D57 A84A9B71 04495B39 B919CC0A B51266EE
  A8930203 010001A3 62306030 0F060355 1D130101 FF040530 030101FF 300D0603
  551D1104 06300482 02617030 1F060355 1D230418 30168014 0537595B CCAD328D
  F8A96B71 7504DDD5 B18A6549 301D0603 551D0E04 16041405 37595BCC AD328DF8
  A96B7175 04DDD5B1 8A654930 0D06092A 864886F7 0D010104 05000381 81005373
  E7975701 5359B622 34EF441C 128529DC 5D666DDD 5DB559D8 D2745F57 653DA577
  0D0F986A 20F401AA 67A4D9EC B8D5585A 603413FC 52D31A05 84DB1F6D C20DE77A
  0548AB83 8CFA0234 24F996DE BE34CC42 EF25880D 46660F90 E0E6ACA7 DBEBA764
  7163E929 C55C7BB3 AA06E4F2 D7576730 78333965 FEC581D1 B0861C71 8DBE
  quit
username Cisco password 7 072C285F4D06
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1234 mode ciphers aes-ccm tkip
ssid WIRELESS
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.1234
encapsulation dot1Q 1234
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
bridge-group 255 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid WIRELESS
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.1234
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
bridge-group 254 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.1234
no ip route-cache
bridge-group 254
interface BVI1
ip address 10.1.1.20 255.255.255.0
no ip route-cache
ip default-gateway 10.1.1.1
ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
whats the switchport config??
Community Member
Below
Edge Switch:
interface GigabitEthernet2/0/48
switchport trunk native vlan 1000
switchport mode trunk
end
A trunk is also configured between the Edge switch and the Core
Community Member
Problem is solved, in the web I had to enable Radio0-802.11N2.4GHz under Services>VLAN
778
