AIR-LAP1142N will not stay associated with WLC 4402
We have put six new AIR-LAP1142N access points on the network.  We have other models of APs online, and they are fine The 4402 controller log shows that 1142s are constantly associating and disassociating. I can see their mac addresses in the listing of wireless APs. At times I can even see their details. The product ID and serial number is not coming over.  They do have an IP address.
I upgraded the controller software to 4.2.209.0, but it made no difference. What is the problem here?
7 ACCEPTED SOLUTIONS
Re: AIR-LAP1142N will not stay associated with WLC 4402
Oh, thats way ... 1142s ONLY work with 5.2 code or newer ONLY ...
Please rate the post if this was helpful ... Thanks
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
I had the exact same problem and George is exactly right. My problem was I had older 1010s and they will not work after version 4,x so you can't use 1010s and 1142s at the same time.
Hey William,
Actually you cant use 1142s at all prior to 5.2 code. 4.2 is LWAPP, 5.2 CAPWAP... 1142s do CAPWAP
Yes, you settings should be stored. I would backup the config just in case. If something happens you can always back down in code ...here is a link how from my site http://www.my80211.com/cisco-wlc-cli-commands/2009/11/12/restore-the-backup-image-on-your-wlc.html
It not best practice to have controllers on different code. Are you running voice over wireless?
Please rate the post if you find this helpful ... trying to get my blue star !LOL
Should work ... just test your mobility groups ... make sure you can roam from one controller to another without having to re ip
Hall of Fame Super Gold
Hi Jon,
No.  The 1130 will work with codes from 4.X, 5.X, 6.X and 7.X.  Cisco is recommending users stay away from 5.X and 6.X codes and upgrade to the newer 7.X code.  The 5.X is on the it's last breath.
Please don't forget to rate useful posts.  Thanks.
There's only one 7.X so far.
Hey William,
Ok, I do have quite a few 1010 APs. Luckily I have two 4402 controllers, so I will leave one at version 4 and upgrade the other to 6.
Will the upgrade keep all of my settings? I am worreod especially about the MAC address filtering list.
Bob
No, we are not running any voice over wireless.
Bob
Hey, folks! I just got a new 1142 and ran into the same issue. I recently upgraded our WLCs to 5.1.151 and it didn't seem to be too difficult a process; but I'm wondering - all our other APs are 1131s. Will they be negatively impacted by going up to the next rev of controller firmware?
Thanks.
Jon Koelker
Hi Jon,
Should it be the very latest 7.xx release?
thanks
gary
Thanks for the help! Upgrading the firmware was just what I needed to solve my problem.
   jk
Thanks for the ratings.
747
