AIR-LAP1262N-E-K9 fail to boot
hello friends
i have 1262 LAP which is fail to boot and went to rommon mode
here are the logs
ap: boot
Loading ""...: permission denied
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
ap: dir
List of filesystems currently registered:
               flash[0]: (read-write)
              xmodem[1]: (read-only)
                null[2]: (read-write)
ap:
ap: flash_init
Initializing Flash...
flashfs[0]: sector 68, block 169 checksum (0x1aa8 != 0xe2f0)
flashfs[0]: writing to flash handle 0x230932c, device 0, offset 0x1520000, length 0x208: Operation Failed
flashfs[0]: sector ptr: {0xa9, 0x44}
...done Initializing Flash.
how to fix it?
many thanks
Everyone's tags (1)
well well
It mens that your IOS image is corrupted and you need to load it again.
The instructions are listed as below:
http://www.cisco.com/en/US/partner/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap22-trouble.html#wp1048378
please make sure to mark the thread as answered upon having correct answer
thanks for your reply
is this image i need to upload
ap3g1-rcvk9w8-tar.124-23c.JA5.tar
what is method to upgrade a image on LAP when AP is in rommon mode like ap:   ????
thanks
Bronze
Just so you know the AIR-LAP1262N-E comes preloaded with LWAPP so it can work with a WLC, and the AIR-AP1262N-E comes pre loaded to work in autonomouse mode.
In either case we can convert the unit from IOS to LWAPP and from LWAPP to IOS.
Here is the correct IOS FIle for the 1262, ap3g1-k9w7-tar.124-25d.JA1.tar.
The IOS files are always k9w7 and the LWAPP files are k9w8.
The file you mention above ap3g1-rcvk9w8-tar.124-23c.JA5.tar is the lwapp recovery image.
You can do these commands:
   flash_init
   ether_init
   tftp_init
then
Your entry might look like this example:
ap: tar -xtract tftp://192.168.130.222/images/c1310-k9w7-tar.122_15.JA1 flash:
yes thats the one.
Same procedure described in the link i have already forwarded to you
Enjoy
2250
