Community Member
Aironet 1042N & 1041N Upgrade FAIL
Product/Model Number : AIR-AP1042N-A-K9
Product/Model Number : AIR-AP1041N-A-K9
The last firmware c1140-k9w7-tar.152-4.JA1.tar release
#archive download-sw /force-reload tftp://ip-address/c1140-k9w7-tar.152-4.JA1.tar
examining image...
Loading c1140-k9w7-tar.152-4.JA1.tar from 172.16.107.44 (via BVI1): !
extracting info (281 bytes)
Image info:
    Version Suffix: k9w7-.152-4.JA1
    Image Name: c1140-k9w7-mx.152-4.JA1
    Version Directory: c1140-k9w7-mx.152-4.JA1
    Ios Image Size: 11059712
    Total Image Size: 12012032
    Image Feature: WIRELESS LAN
    Image Family: C1140
    Wireless Switch Management Version: 7.5.1.73
Extracting files...
# ANY FILES
extracting info.ver (281 bytes)
[OK - 12052480 bytes]
Deleting current version: flash:/c1140-k9w7-mx.124-25d.JA2...done.
New software image installed in flash:/c1140-k9w7-mx.152-4.JA1
Configuring system to use new image...done.
Requested system reload in progress...
after complete process have KERNEL PANIC when client authenticate into de AIRONET, in the two AIRONET !!!
=== Start of Crashinfo Collection (12:19:09 PCTime Tue Oct 22 2013) ===
For image:
Cisco IOS Software, C1040 Software (C1140-K9W7-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:28 by prod_rel_team
---- Partial decode of process block ----
Pid 159: Process "Dot11 ARP Cache Protocol" stack 0x4B14350  savedsp 0x20BAA2C
Flags: analyze prefers_new
Status     0x00000000 Orig_ra   0x00000000 Routine    0x007DAF14 Signal 0
Caller_pc  0x00000000 Callee_pc 0x00000000 Dbg_events 0x00000000 State  0
Totmalloc  226444     Totfree   139316     Totgetbuf  0
Totretbuf  0          Edisms    0x0        Eparm 0x0
Elapsed    0x2        Ncalls    0x32       Ngiveups 0x0
Priority_q 4          Ticks_5s  0          Cpu_5sec   0        Cpu_1min 0
Cpu_5min   0          Stacksize 0x1770     Lowstack 0x1770
Ttyptr     0x20925F8  Mem_holding 0x17050    Thrash_count 0
Wakeup_reasons      0x0FFFFFFF  Default_wakeup_reasons 0x0FFFFFFF
Direct_wakeup_major 0x00000000  Direct_wakeup_minor 0x00000000
Regs R14-R31, CR, PC, MSR at last suspend; R3 from proc creation, PC unused:
     R3 : 00000000  R14: 00000000  R15: 00000000  R16: 00000000  R17: 00000000
     R18: 00000000  R19: 00000000  R20: 00000000  R21: 00000000  R22: 00000000
     R23: 00000000  R24: 00000000  R25: 00000000  R26: 00000000  R27: 00000000
     R28: 041480C8  R29: 04AD71BC  R30: 00000000  R31: 00000000  CR: 20000028  -
     PC : 002AA9C8  MSR: 00029230
And more log of KERNEL PANIC !!!
How can explain this ???
Only can tell that after the upgrade dot11radio0 and 1 in the AIRONET with dual band, shutdown the radios and two machines work fine without errors, but up the radios and authenticate client and KERNEL PANIC again!
Downgrade to c1140-k9w7-mx.124-25d.JA2 and work again !!!
Please if anyone have the same problem, comment!
Everyone's tags (2)
Please reach out our TAC , http://www.cisco.com/techsupport and open a case !!
This might be a problem taht will be solved by TAC. Agreed with Saurav
Community Member
Abhishek, Saurav what is that mean?
Hall of Fame Super Gold
Alex,
Stay away from autonomous IOS versions  15.X.  Stick with 12.4.
347
