11-09-2006 11:07 AM - edited 07-03-2021 01:13 PM
I was under the impression that the Aironet 1100 supports 802.3af POE. I purchased a NetGear FS108P POE switch, however, when I plug in the 1100, it does not receive any power.
I have seen references in the documentation to a Cisco inline power injector and a Cisco Catalyst switch that can provide POE to the 1100 and maybe they will work, however, will the 1100 only work with those devices?? If so, it would seem that the 1100 really doesn't support the 802.3af standard and that Cisco's implementation of POE is proprietary.
Any input would be appreciated.
Michael
11-09-2006 11:26 AM
Would the AIR-PWRINJ3(Power Injector for 1100 1200 Series) or AIR-PWR-A (Power Supply in 100-240VAC Out 48VD 380MA-for 1100 1200 Series) solve my problem? Would I need to purchase both units?
Michael
11-09-2006 12:20 PM
Hi Michael,
As you have discovered (unfortunately) is that the 1100 only supports Cisco Pre-standard PoE :( Have a look;
Single 802.11g radio offering 54 Mbps of capacity
2.4 GHz integrated diversity dipole antennas
Available in an autonomous version only
16 MB of memory with 8 MB of storage
Operating temperature range of 32 to 104?F (0 to 40?C)
**Inline power support (Cisco pre-standard)**
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps4570/prod_brochure0900aecd8035a015.html
The good news is that either of the options you listed will work just fine. I would go for the power injector probably just for neatness sake.
POWERING OPTIONS
The Cisco Aironet 1100 Series can be powered either locally using the AC-DC power adapter, or over the Ethernet cable when coupled with a device capable of delivering in-line power, such as an in-line power-capable Cisco Catalyst? switch, Catalyst in-line power patch panel, or Cisco Aironet Power Injector.
The AC-DC power adapter is included with the access point and can also be ordered as a spare part. The Cisco Aironet Power Injector can either be configured to the order or can be ordered separately.
You can use either;
AIR-PWR-A= Cisco Aironet Power Supply-Input 110-240VAC, Output 48VDC, 380 mA-for 1100 and 1200 Series
AIR-PWRINJ3= Cisco Aironet Power Injector for the 1100 and 1200 Series Access Points
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_data_sheet0900aecd8045690f.html
Hope this helps! And good luck!
Rob
Please remember to rate helpful posts.....
11-09-2006 02:40 PM
Rob:
Thanks. Based on my research prior to your post, I came to the following conclusion:
- the AIR-PWRINJ3 is required as it supplies power (via network cable) to the Aironet 1100.
- the AIR-PWRINJ3 needs power provided to it and the options are either the AIR-PWR-A or the power supply which comes with the Aironet 1100. Since I have the Aironet power supply, I don't need the AIR-PWR-A.
The information on the Cisco site it very confusing, misleading and incomplete. When my power injector arrives, hopefully I'll have everything I need.
Now, will Cisco reimburse me for the 802.3af POE switch I bought which didn't work???
Michael
11-10-2006 05:45 AM
Hi Michael,
Sorry, I didn't explain this very well. Have a look at the diagram in the attched link. It shows the parts needed for the different power options. You are correct that with the power supply that shipped with the AP plus the power injector, you should be good to go!
You are right about Cisco docs, you do have to do alot of research sometimes :(
Hope this helps!
Rob
