Community Member
Aironet 1130ag GUI problem
i can't have access into Cisco Aironet 1130ag via GUI. Meanwhile, i could ping it. Kindly assist
Hall of Fame Super Silver
Re: Aironet 1130ag GUI problem
Did you configure the ap correctly, make sure you have ip http server or http secure-server configured.
-Scott
Community Member
Meanwhile,its not ap but Lwap.
If th eap is not autonomous, then you can't http or https to it. You need a WLC and have that ap join that controller to configure that ap. If you don't have a WLC, then you need to convert that LAP to an autonomous ap.
-Scott
Hall of Fame Super Red
Hi Fafolahan,
Just to add a note to the good info from Scott (+5 points here Scott :)
Converting a Lightweight Access Point Back to Autonomous Mode
You can convert an access point from lightweight mode back to autonomous mode by loading a Cisco IOS Release that supports autonomous mode (Cisco IOS release 12.3(7)JA or earlier). If the access point is associated to a controller, you can use the controller to load the Cisco IOS release. If the access point is not associated to a controller, you can load the Cisco IOS release using TFTP.
Using a TFTP Server to Return to a Previous Release
Note This section does not apply to Cisco C3201WMIC and Cisco C3201LAP.
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View > Show hidden files and folders.
Step 4 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, and c1240-k9w7-tar.default for a 1240 series access point.
Step 5 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 6 Disconnect power from the access point.
Step 7 Press and hold MODE while you reconnect power to the access point.
Step 8 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 9 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 10 After the access point reboots, reconfigure it using the GUI or the CLI.
From this excellent doc;
http://www.cisco.com/en/US/customer/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
Hope this helps!
Rob
Community Member
I followed the procedure strictly but it was given error opening files when downgrading the Lwap to Ap. thanks alot for your assistance.
That is most likely due to wrong file name, file not in the correct tftp directory, firewall on the pc blocking tftp, wrong ip address on pc, tftp server issue. Try using 3cdeamon tftp server. Also console into the so while doing the upgrade and post the log.
-Scott
Community Member
I dont think i should have problem with ip address,tftp directory,or file name. am using solarwinds tftp server. i will try 3cdeamon and get back to you.thanks
Community Member
Kindly assist,am still having problem with downgrading,%error opening file (no such file or directory)Loading
"flash:/c1130-rcvk9w8-mx/c1130-rcvk
9w8-mx"...########################################
From TFTP server:
TFTP connected from 10.0.0.1:1024 on 8/19/2008 , GET. Transmission
failed.Access failed.Access to the path 'E:\Programs
Files\SolarWinds\TFTPServer\c1130-k9w7-tar.default' is denied .
'Am waiting for your response. thanks
Did you verify the settings on your TFTP program. Download 3cdeamon and try that. Always worked for me.
-Scott
1037
