Community Member
Aironet 1131AG, Will this work?
I need to connect a lab of 24 wireless computers to a LAN. I need to be able to login to a Novell server, obtain a DHCP address from the Novell server and have Internet access. The site is setup with a VLAN. The WAP will be in the same room so range is not an issue. Will the 1131AG work okay for this or is there a better solution? Cost is a big factor.
Community Member
Re: Aironet 1131AG, Will this work?
Not necessarily 1131AG AP. Any autonomous AP will be ok for this. If you are in a controller environment, then a LWAPP capable AP is needed.
Community Member
The 1131ag AP will be a good solution for this. I have many 1131's running with 20 - 15 clients each without issues. FYI 1131ag is come in either lwapp or IOS. So unlike stated above you can use the 1131 without a controller.
204
