Aironet 1141 won't power on
I have a Aironet 1141n that I can't get to power on using poe, I know the poe is good because it works with others. Does anyone have any ideas to try or know what is a common failure in these? Also where can I order a new board for it. I'm guessing it's would be a quick fix as there are only the main board and the radio inside.
Hall of Fame Super Silver
I don't think you will be
I don't think you will be able to "FIX" that yourself.  Your better off looking on ebay and picking up a new AP to be honest.
Scott
-Scott
They don't sell replacement
They don't sell replacement boards for these?
Hi, If it's dead on arrival,
If it's dead on arrival, better replace the AP from your partner or with Cisco if it's covered under warranty or contract. if this was working fine and if it has gone down now, then it's better to check for your warranty and get it replaced from wherever you got it.
Salma
30
