Aironet 1200 Series AP in Lightweight Mode
I try to connect an Aironet 1200 Series AP in Lightweight Mode to a Cisco 2000 Series Controller. This AP had a SSC (Self Signed Certificate). I need his SHA1 Key Hash in order to add this AP in the Autorization List of the controller. How can I get this Key Hash? or how can I connect this AP to the controller without this key?
Thanks for your help!
  • Getting Started with Wireless
Re: Aironet 1200 Series AP in Lightweight Mode
Did you upgrade the AP from fat to thin yourself ?
If so, the hash key is in the file configxxxx.csv generated by the upgrade tool.
If you bought a LWAPP ready 1200 AP, there is no need to add the AP in the authorization list on the ctl. It should join out of the box.
Hello, it looks like I am having the same problem. I've bought 2 C1232AG ap's. With the normal IOS version. Our distributor told as it was very easy to convert them to lwapp mode. On the cisco site I read that you have to use the convert tool. Our distributor told me it was easier to do it without. I tried the whole morning with no succes. I get errors saying that the certificate isn't right, something like that.
I tried to contact our distributor but the responsible person has a day off today and I would like to go on. (already behind on my time schedule)
Could someone help me?
Thnx!
You need a controller to get the job done.
Go here and follow the procedure:
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html
Bronze
You have to use the upgrade tool to convert. The upgrade tool does more than just load a new image. It also creates the self signed certificate (SSC). It also adds the AP to the controller authorization list.
I too am trying to find out the SHA1 Key Hash from a previously converted AP.
Bronze
Looks like the Upgrade Tool 1.0 did not generate the hash properly. I have a zero-byte Config_15Feb2006_174732 file. Any suggestions?
I have run into this problem too, when performing the upgrade without a WLC. You need to have a controller connected, the the key hash is generated properly.
Bronze
Thanks Chris,
I have a WLC on a L3 interface from the AP. Trying to use Option 43 - getting the IP but not the option so far. It looks like the Upgrade Tool logged into the WLC but didn't enter the cert.
From log files:
(Cisco Controller)
User: ********
Password:********
(Cisco Controller) >config auth-list add ssc
Incorrect input! Use 'config auth-list add '
(Cisco Controller) >config auth-list ap-policy ssc enable
(Cisco Controller) >save config
Are you sure you want to save? (y/n) y
Configuration Saved!
(Cisco Controller) >logout
2006/02/15 17:48:31 DEBUG 172.16.95.9 Opening a telnet connection to the Controller
2006/02/15 17:48:32 DEBUG 172.16.95.9 Telnet connection to the Controller opened
2006/02/15 17:48:32 DEBUG 172.16.95.9 Configuring the Controller with
2006/02/15 17:48:32 DEBUG 172.16.95.9 Successfully configured the Controller with 132.183.54.86
2006/02/15 17:48:32 DEBUG 172.16.95.9 Upgrade Tool is exiting, Saving Controller configuration.
2006/02/15 17:48:32 DEBUG 172.16.95.9 Controller Configuration has been saved successfully.
2006/02/15 17:48:32 DEBUG Upgrade process is completed
358
