06-26-2008
06:50 AM
- last edited on
07-03-2021
04:05 PM
by
cc_security_lab
HI
I just bought a AP 1230 B ( out the box) never beeing used ) and i want to upgrade it to the latest ISO release , i downloaded the c1200 kw---------------- tar file from cisco , when i try to do Http update i iether get a error message (invalid file format ) or the Upgrede window timer conts forever instead of 5 to 10 minutes that it shoul take , if i try to do tftp it fails right away . any ideas , i will try to update it using the CLI tonight , what will it be the right command to execute the update ?
thanks
06-26-2008 06:16 PM
Your problem is two fold the current images exceed the 4Mb limit for HTTP transfers, you need to use TFTP to transfer the new image also the old AP images don't support transfers greater than 4mb.
the process is two step first upgrade to 12.2(13) with TFTP this version while less than 4mb supports downloads over 4Mb then youu can load a 4Mb+ image using tftp.
Good luck
Bill
06-26-2008 06:31 PM
HI Bill
I'm Currently using 12.2(13)
i copied and pasted the info
c1200-k9w7-tar.122-13.JA1
System Software Version: 12.2(13)JA1
Bootloader Version: 12.2(8)JA
System Uptime: 1 day, 9 hours, 8 minutes
I tried to upgrade it using the CLI , I'm using filzila as an Ftp server . when i run the command ap#$nload-sw /overwrite /safe ftp://192.168.1.5/c1200-k9w7-tar.123-8.JA2.tar i get this error ...ap#$nload-sw /overwrite /safe ftp://192.168.1.5/c1200-k9w7-tar.123-8.JA2.tar
examining image...
%Error opening ftp://192.168.1.5/c1200-k9w7-tar.123-8.JA2.tar (No such user)
ERROR: Failed to open archive file ftp://192.168.1.5/c1200-k9w7-tar.123-8.JA2.ta
r . I created a user on my Ftp with the same credectials as the AP Any ideas ,
06-26-2008 06:39 PM
You need to use the GUI it is much simpler.
you also need to use a TFTP server here is the link to the one Cisco usually reccomends.
