Aironet 1250 with 2x 2.4Ghz Antenna
I need to upgrade a 1230 to the new Aironet 1250 at a location. I have only 2 external antennas at that location.
I understand that you still can run 802.11n with 2 antennas.
But I can not find anywhere in WLC 5508 v7.2 that I can disable the middle nut (C)
Please advise.
Everyone's tags (4)
1 ACCEPTED SOLUTION
the middle nut is a Rx only, so you wouldn't need to disable it really.
But if you go to Wireless > 802.11a (on the left) > then pick the AP you want to configure, you can uncheck that box.  This is a per AP config, so could take you a while.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
It works, thank you
Hall of Fame Super Silver
Re: Aironet 1250 with 2x 2.4Ghz Antenna
When the ap is joined to the wlc, you can click on the blue arrow on the right side of the ap listing that says configure. IIRC, it there where you can set what ports you will use.
Scott Fella
Sent from my iPhone
-Scott
296
