06-01-2008 07:33 PM - edited 07-03-2021 03:57 PM
Do both the Aironet 1252 & WLC Module for ISR Routers support HREAP ???
06-02-2008 03:51 AM
The WLCM & WLCM-E for the ISR do not support the below:-
- Servie Port
- 1000Base-T modules
- VPN Termination
- QoS per-user bandwidth contract
- Layer 2 LWAPP
- Spanning Tree
- Port Mirroring
- AppleTalk
- Layer 3 security polocies not supported - for VPN termination
Everything else a 44xx can do, the WLCM & WLCM-E can.
HTH.
06-02-2008 06:44 PM
Hi, Thanks for that Information, do you know about the aironet 1252?? As I can only see reference to 1240
06-02-2008 06:49 PM
What exactly are you looking for?
Here is a link to the 1252's:
http://www.cisco.com/en/US/products/ps6973/index.html
06-02-2008 07:01 PM
I have search that site already looking to see if the 1252 support HREAP without luck, do you know if they do support it?
06-03-2008 12:44 AM
As far as I would imagine - it should support it, as longs as it's LWAPP and not autonomous. The only difference I can see on the 1252 is the N radio. However you could ask your cisco reseller to confirm?
HTH.
06-03-2008 04:27 AM
Hi Mark,
Here is a note to add to the great help from Scott and Andrew. These are the latest H-REAP requirements;
Requirements
H-REAP is only supported on the 1130AG, 1240AG and **1250 access points and on the Cisco 2000, 2100 and 4400 Series Unified Controllers, the Catalyst 3750G Integrated Wireless LAN Controller Switch, the Cisco WiSM, and the **Controller Network Module for Integrated Services Routers.
From this excellent doc;
H-Reap Design and Deployment Guide
http://www.cisco.com/en/US/products/ps6521/products_tech_note09186a0080736123.shtml
Hope this helps!
Rob
06-03-2008 07:21 PM
Thanks Rob, thats exactly what I was looking for!
