Aironet 1310 Point to Multipoint Configuration.
According to the installation manual in a point to multi point configuration one device should be a root-bridge a the others must be non-root bridge. This is working fine. From the root bridge I can see the true CDP and ping the other devices. with out any problem. Even Http and set up the non-root bridge?s configuration.
The problem begins when I am trying to ping from a non-root bridge to another non-root bridge and have access to the resources in that side of the Lan.
The ip Addressing scheme seems to be fine , all the devices are in the same sub-net. Know what am I missing in the configuration of the root bridge so he can permit the communication between all non-root bridges?
TKS
1 REPLY
Re: Aironet 1310 Point to Multipoint Configuration.
I didnt have the time to check your configuration but I can give you a link that mind help you. I try it as point to multipoint and i could ping between the two non root aironet
http://www.cisco.com/en/US/customer/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
490
