11-09-2006 07:14 PM - edited 07-03-2021 01:13 PM
We will be using two 1310s simply as a long lan cable between a single computer and a single mobile data collection instrument. We know others have been successful. No security needed, max throughput is important. Is there a tech note somewhere that explains this minimal setup?
Any help would much appreciated.
Solved! Go to Solution.
11-10-2006 05:55 AM
Hi Julian,
Perhaps this doc will help get you started;
Wireless Bridges Point-to-Point Link Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
Hope this helps!
Rob
Please remember to rate helpful posts.....
11-10-2006 05:55 AM
Hi Julian,
Hope this helps!
Rob
11-11-2006 07:02 PM
Hi Rob
That was just what I needed and had looked in the wrong place for it. Followed instructions and it all worked. Setting the IP initially was not well documented but finally got it- typed help and figured it out.
Thanks for your help.
JH
