Aironet 1600 with 2504 WLC
Any ideas please ?
Oct 15 17:36:10.854: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_31:df:24'running version 7.0.220.0 is rejected.
Oct 15 17:36:10.854: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
Oct 15 17:36:10.854: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
Oct 15 17:36:10.854: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
Oct 15 17:36:10.854: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.14.13.1
Oct 15 17:36:20.854: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_31:df:24'running version 7.0.220.0 is rejected.
Oct 15 17:36:20.854: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
Oct 15 17:36:20.854: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
Oct 15 17:36:20.854: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
Oct 15 17:36:20.854: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.14.13.1
Oct 15 17:36:30.854: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_31:df:24'running version 7.0.220.0 is rejected.
Oct 15 17:36:30.854: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
Oct 15 17:36:30.854: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
Oct 15 17:36:30.854: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
Oct 15 17:36:30.854: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.14.13.1$ailed to handle capwap control message from controller
Not in Bound state.
Oct 15 17:36:46.354: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Oct 15 17:36:49.366: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
Oct 15 17:36:49.430: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.14.13.32, mask 255.255.255.0, hostname APf872.eae4.a93c
Oct 15 17:36:57.358: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Oct 15 17:37:07.358: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_31:df:24'running version 7.0.220.0 is rejected.
Oct 15 17:37:07.358: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
Oct 15 17:37:07.358: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
Oct 15 17:37:07.358: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
Oct 15 17:37:07.358: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.14.13.1
1 ACCEPTED SOLUTION
VIP Purple
Re: Aironet 1600 with 2504 WLC
1600 series AP required 7.4.100.0 software code  or above to work with. Pls upgrade your WLC software
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Rasika
VIP Purple
Rasika
I don't have support contract with Cisco, what to do, can I use a version from any file share website??
1600 Series AP need minimum  WLC 7.4 code to join.. Please upgrade and try..
641
