Aironet 1600 works only guest SSID
Hi there,
I'm trying to configure an Aironet 1600 for using two SSID, one in guest mode and one hidden.
The first SSID (guest) works fine, but the hidden not. I've the same configuration on some Aironet 1200 and works fine. I've already updated the software at the latest (15.2(4)JB4) version but did not change the issue.
Can anyone help me?
Fabio
here is the configuration:
version 15.2
no service pad
service password-encryption
hostname XXXXXXXX
logging rate-limit console 9
enable secret 5 XXXXXXXX
enable password 7 XXXXXXXX
no aaa new-model
clock timezone +0400 4 0
no ip cef
dot11 syslog
dot11 ssid SSID1
   vlan 1
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 XXXXXXXX
dot11 ssid SSID2
   vlan 2
   authentication open
   guest-mode
dot11 guest
power inline negotiation prestandard source
username vpap privilege 15 password 7 XXXXXXXX
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm tkip
 encryption vlan 2 mode ciphers aes-ccm tkip
 encryption vlan 1 mode ciphers aes-ccm tkip
 ssid SSID1
 ssid SSID2
 antenna gain 0
 stbc
 beamform ofdm
 station-role root access-point fallback shutdown
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
 encapsulation dot1Q 2
 no ip route-cache
 bridge-group 2
 bridge-group 2 subscriber-loop-control
 bridge-group 2 spanning-disabled
 bridge-group 2 block-unknown-source
 no bridge-group 2 source-learning
 no bridge-group 2 unicast-flooding
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 antenna gain 0
 peakdetect
 no dfs band block
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0.1
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0.2
 no ip route-cache
 bridge-group 2
interface BVI1
 ip address X.X.X.X 255.255.255.0
 no ip route-cache
ip default-gateway X.X.X.X
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
sntp server X.X.X.X
sntp server X.X.X.X
end
1 REPLY
VIP Purple
Fisrt of all you are creating
Fisrt of all you are creating more then one ssid then u must use : mbssid guest-mode
add these commands on your config
dot11 ssid SSID1
mbssid guest-mode
dot11 ssid SSID2
mbssid guest-mode
guest-mode
int dot11radio0
mbssid
Try this and let me know if it works. and they you can try to hide ssid and test again.
91
