Aironet 2600 - DHCP Address Lease Problem
     Hello, I am having trouble with my autonomous Aironet 2600 that is configured as a DHCP server to assign addresses to wireless clients. After much troubleshooting, clients are able to successfully connect with WPA encryption on and can access the Internet. The problem I am now having is that although the address lease time is set to a very low interval (1 min), the DHCP server will keep assigning addresses in sequence rather than revert to a lower address that is to my knowledge available and not already leased to a client. I assumed that the DHCP server would try to use the lowest available address when assigning to clients in order to be efficient. Is this assumptions correct?
The address for the AP is 192.168.3.1 and is set as static.
I have setup two excluded address ranges.
1st Excluded Range - 192.168.3.0 to 192.168.3.25 is reserved for future access points and other wireless equipment.
2nd Excluded Range - 192.168.3.125 to 192.168.3.255 is reserved for client address assignment by future access points.
This should leave a total of 100 available addresses (more than I need) that can be assigned by the AP DHCP server to wireless clients at this location.
I have also set up a DHCP pool
network 192.168.3.0      255.255.255.0
default-router 192.168.3.25 (This is a firewall which all traffic must pass through for security and web context filtering. This is also set as the gateway)
dns-server xxx.xxx.xxx.xxx
I will post the configuration below (slightly edited for security reasons). If anyone has any idea why this is happening or sees anything incorrect please let me know. Any help is greatly appreciated, thanks!
! Last configuration change at 01:09:29 UTC Mon Mar 1 1993 by Mike
version 15.2
no service pad
service password-encryption
hostname ADAM1-AP1
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
no ip routing
ip dhcp excluded-address 192.168.3.0 192.168.3.25
ip dhcp excluded-address 192.168.3.125 192.168.3.255
ip dhcp pool ADAM
lease 0 0 1
dot11 syslog
dot11 ssid ADAM-AP1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii x xxxxxxxxxxxxxxxxxxxx
username Mike privilege 15 password x xxxxxxxxxxxxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid ADAM-AP1
antenna gain 0
stbc
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
stbc
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.3.1 255.255.255.0
no ip route-cache
ip default-gateway 192.168.3.25
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
transport input all
end
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
How DHCP dishes out IP address is like "fet1sh", it's whatever-floats-your-boat.
Some manufacturer dishes out from the lowest IP address and some would start from the highest IP address.
What you are seeing, in my opinion, makes sense.  Ok, so you make your IP address 1 minute lease time.  When the machine doesn't respond from the DHCP the DHCP server will say, "it's gone and won't need the IP address".  So why did you not get the same IP address?  Probably because of round-robin.
If you really want to "bind" a specific MAC address to a DHCP IP address, then this is possible.
Wow.  I've never seen someone configure the lease time to be lower than 30 minutes.  This is a first for me!
Sorry, I don't get what the problem is.  Can you elaborate?
     Ill try my best to explain the problem more in depth. I originally had the lease time set to 5 hours. I setup the excluded ranges to allow for 100 addresses to be assigned which is way more than enough assuming that the inactive leases would expire after five hours and the addresses attached to those leases would become available for reassignment to another client. I connected three wireless devices (a laptop, an iphone, and an itouch) up to the access point and was assigned the following addresses.
Laptop - 192.168.3.26
IPhone - 192.168.3.27
Itouch - 192.168.3.28
     The DHCP server assigned the addresses according to my ranges and all the devices worked. I left work for the day shortly after. I came back the next day (well over five hours later) and connected the same three wireless devices up to the access point again. I though since the leases for the addresses 192.168.3.26, 192.168.3.27, and 192.168.3.28 from the day before should have expired by this point that when I reconnected the wireless devices they should have received these same addresses because the are the bottom three addresses within my pool. They did not, instead they were issued the following addresses.
Laptop - 192.168.3.29
IPhone - 192.168.3.30
Itouch - 192.168.3.31
    At this point I changed the lease time to 1 minute to further test this issue. After changing the least time to 1 minute I saved the change to the startup-config and restarted the access point. I connected my three devices and got the following addresses.
      I disconnected the devices and waited well over a minute for the leases to expire. I then reconnected the devices and again instead of assigning the lowest available addresses within the pool (192.168.3.26, 192.168.3.27 and 192.168.3.28) it assigned the following.
      Either I am misunderstanding how the DHCP server leases work or the DHCP server is not working properly. It was my understanding that when a client connects to the AP that the DHCP server try's to assign the client the lowest numbered available address within the pool. If the lease attached to the address 192.168.3.26 expires, that address should become available and should be assigned to the next device that connects because its the first available address in the pool. Instead the DHCP server assigns 192.168.0.27 to the next connected device when 192.168.0.26 is not being used at all.
     This happening creates a problem for me because even though I have 100 available addresses, if the DHCP server just keeps assigning addresses in sequence like this, eventually I will run out of addresses and the only way to fix the problem would then be to restart the access point. I hope that was not too confusing and better explained my problem. Again thank you for your help with this issue.
1181
