aironet 340 losses connection with lan
I have set up a wireless network with one access point. Everything is working fine for one minute and then they access point seems to have lost connection with the wired network. It starts up all over again.
The leds are reacting the same as when I startup the access point.
What can be my failure in configureing?
thanks mark
Re: aironet 340 losses connection with lan
Could be an interference issue but without more information it will be quite hard to determine. Head over to the Wireless Troubleshooting Center to get started:
http://www.cisco.com/public/support/wireless_launch.html
ngk
Mark,
I am experiencing the same problem with Aironet 350, it was working fine for a while, but when I power on the unit the 2nd time, I was unble to ping to the AP. Did you manage to solve the problem? If you did appreciate if you could share with me how you did it.
Kevin
278
