Aironet 350 Bridge Connectivity
We have just installed 2 350 Bridges about 150 yards apart. We are experiencing some throughput issues. The thing that bothers me, if I ping the bridge that is plugged into the wired side from a PC that is plugged into the wired side, I see a large flucuation in the response time. 80% of the time it is around 1-2ms but it will routinely jump up to anywhere around 200-1500ms and even time out. Would appreciate any help. Thanks.
1 REPLY
Bronze
Re: Aironet 350 Bridge Connectivity
There could be some kind of interference that is affecting the ping times. You may need to upgrade the firmware to the latest code as it could be a firmware issue as well.
145
