Aironet AP 1240 having a problem
Hi Team,
I am facing a problem while connecting to Access Point
below is the Ap Log Pls suggest what is the reason why i am not able to connect to this AP.
1 Sep 20 17:55:38.775 Information Interface Dot11Radio0, Deauthenticating Station 0019.d259.6f92 Reason: Sending station has left the BSS
2 Sep 20 17:49:26.368 Information Interface Dot11Radio0, Deauthenticating Station 0019.d258.fb33 Reason: Sending station has left the BSS
3 Sep 20 17:39:36.881 Information Interface Dot11Radio0, Station ap 0019.d259.6f92 Associated KEY_MGMT[NONE]
4 Sep 20 17:39:23.029 Information Interface Dot11Radio0, Deauthenticating Station 0019.d259.6f92 Reason: Sending station has left the BSS
5 Sep 20 17:39:19.905 Information Interface Dot11Radio0, Station ap 0019.d259.6f92 Associated KEY_MGMT[NONE]
6 Sep 20 17:38:59.682 Information Interface Dot11Radio0, Station ap 0019.d258.fb33 Associated KEY_MGMT[NONE]
7 Sep 20 17:38:27.534 Information Interface Dot11Radio0, Deauthenticating Station 0019.d258.fb33 Reason: Sending station has left the BSS
Nalin
Remove the authentication and try to connect the clients with open authentication!!
From the logs:-
It seems client is associating and again disassociating with the AP within no time.
seems to be an interference issue.
Please check if you are getting the proper signal on the client.
Have you tried checking antennae or other client or interference?
196
