Aironet-LAP1142N update firmware
I would like to update the firmware of this AP but I'm having problems. The commands seems to be not complete
APa493.4c46.8e83#?
Exec commands:
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapp            lwapp exec commands
  mkdir            Create new directory
  monitor          Monitoring different system events
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  ping             Send echo messages
  pwd              Display current working directory
  release          Release a resource
  reload           Halt and perform a cold restart
  rename           Rename a file
  renew            Renew a resource
  rmdir            Remove existing directory
  send             Send a message to other tty lines
  set              Set system parameter (not config)
  show             Show running system information
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  test             Test subsystems, memory, and interfaces
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  upgrade          Upgrade software
  verify           Verify a file
  where            List active connections
APa493.4c46.8e83#
Im looking for 'archive' command.
Everyone's tags (3)
Hall of Fame Super Silver
Re: Aironet-LAP1142N update firmware
This is a lightweight access point and requires a wlc. These get updated by the wlc it joins. If your looking for an autonomous ap, then you will need to convert that ap to autonomous.
-Scott
Here is a link or you can search for lightweight to autonomous
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
-Scott
1401
