Community Member
Aironet Radius - logging in not mapping drives
Still working the kinks out of my new 1141ns.
My clients are set up to authenticate with the local radius server built into the 1141n.  I'm running LEAP and EAP-Fast on my clients.
The clients are having an issue where a particular network drive/resource is not mapping for them.  Its the same resource for all clients.
They all have 3 drives that map, only 2 out of 3 of them are mapping when they access the 1141n.
I have AD login scripts setup to accomplish this, its like the 1141n Radius isn't falling back on AD or something.
Any ideas and thanks!
Jeff
1 REPLY
Gold
Re: Aironet Radius - logging in not mapping drives
Typically to get a login script to work you need to also do machine authentication.  The reason is that the PC is still doing user auth when the login script gets started so they don't get the entire script, if any.
158
