Aironet VxWorks and IOS
Is it true "You cannot have a mixed environment of APs running VxWorks and IOS work with the BBSM"
Bronze
Re: Aironet VxWorks and IOS
The statement you make is true if you are using any vlans internal to the BBSM. There is an issue that is being worked related to vlans and the polling of the bridge mib in these devices. If you have no vlans a mix of vxworks and IOS Aps should be just fine.
Thank you for your response, so if I upgrade all my access points to IOS (which is about 50+) I will no longer have issue? DO you happen to know any bug ID regarding this?
Thanks.
Bronze
I have never seen an issue with the APs running IOS. I would recommend using the packet version of the Dlls when you set them in network elements. No there is no bug at this point. We having been discussing it internally to see if it is a configuration issue or a bug.
130
