Airplay issues
I have bt infinity coming in to a draytek 2860 which then connects to a ESW POE cisco switch. Also attached is a 2504 WLC and 5 AP's.
When I connect aiport express directly to draytek, airplay works fine, but if I connect through switch or wireless airplay will not work.
Is there anything I can do to make it work
I Cant access the WLC via gui for some reason so I can only use putty to make any changes.
Can someone please help.
Is there any setting that I need to make on WLC or switch level to make this work.
Hall of Fame Super Silver
Airplay issues
There are a few things... you can enable multicast on the switch and or use mDNS on the WLC running v7.4 or later.
Bonjour Deployment Guide
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1100-series-access-point/113443-cuwn-apple-bonjour-dg-00.html
Bonjour v7.4
http://www.cisco.com/c/en/us/td/docs/wireless/technology/bonjour/Bonjour74/Bonjour_Deployment.html
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Airplay issues
Hi Scot
Thank you so much for the reply.
I am unable to get on the gui for WLC and the switch does not let me in as it cant get through the username and password. I do not want to reset the switch as I will loose a lot of settings on it. So if I can make the changes on WLC will it work?
Also what options do I have to get on the GUI for wlc as I am sure the ip address is correct but nothing comes up on the web interface.
I am connected to the same subnet.
Do I need to put like a port number at the end or use https ?
Re: Airplay issues
You can try to enable broadcast forwarding, or else upgrade to v7.4.121.0 which has mDNS gateway and that should help.
This link explains mDNS gateway:
Scott
-Scott
Re: Airplay issues
Thanks for the reply, I went through the links that you posted but is there any way you could help me to go into the WLC in gui mode. I am sure about the ip add on WLC but it would not open the gui interface.
Thanks in advance.
Re: Airplay issues
Try accessing the GUI from a wired device not a wireless device. Try different browsers and try both http/https.
If you can access the GUI after this, reboot the WLC.
-Scott
Re: Airplay issues
Hi I tried that but to no avail
Interface Name................................... management
MAC Address...................................... f0:29:29:88:d7:80
IP Address....................................... 192.168.1.119
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.1.254
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 192.168.1.254
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Disabled
Does this give you any idea of what I need to enable
Is it possible that you give me the CLI command to do that as I still cant get into GUI
Re: Airplay issues
Hi Scott
Thanks for this, it asked me to reboot the router which I did but its still same
http or https on ie or chrome it still does not work
You said try wired so do i connect to console port or port 1 to 4
Airplay issues
Console port is only CLI.  Is your WLC functional at the moment?  The reason I ask is because something isn't righ either the config is the issue or the image or WLC is corrupt.  Let me know if it is functional.
Scott
-Scott
Re: Airplay issues
Hi Scott
It only works if I work on it via putty
GUI has never worked for me on this
The initial cofig as well was all through putty
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.60
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_88:d7:84
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 3 mins 2 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Re: Airplay issues
webmode looks enabled now
RF-Network Name............................. cornwall
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 0.0.0.0
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
MLD snooping................................ Disabled
MLD timeout................................. 60 seconds
MLD query interval.......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
--More-- or (q)uit
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth CMCC Support ...................... Disabled
Web Auth Redirect Ports .................... 80
Web Auth Proxy Redirect  ................... Disable
Web Auth Captive-Bypass   .................. Disable
Web Auth Secure Web  ....................... Enable
Fast SSID Change ........................... Disabled
AP Discovery - NAT IP Only ................. Enabled
IP/MAC Addr Binding Check .................. Enabled
CCX-lite status ............................ Disable
oeap-600 dual-rlan-ports ................... Disable
oeap-600 local-network ..................... Enable
mDNS snooping............................... Disabled
mDNS Query Interval......................... 15 minutes
Re: Airplay issues
Well you should be able to http then, not https
Scott
-Scott
Re: Airplay issues
Hi Scott
You mentioned connecting wired to wlc, which port should I use as a wire from port 1 goes to my switch which has all the access points connected to it
I have tried ie, firefox safari and chrome http and https as i enabled that too and nothing comes up.
Airplay issues
When I say wired... i mean for a machine that is wired to a switch.... the WLC is connected to your network and functional or not?
Scott
-Scott
Re: Airplay issues
Hi Scott
By functional you mean whether its working or not?
The WLC connects to switch and the switch has 5 access points connected to it and the wireless is working
The switch is connected to about 10 machines and they all are working
Airplay issues
Okay... well try this in the CLI:
config network mgmt-via-wireless enable
Scott
-Scott
Re: Airplay issues
Hi Scott
Thank you so much. This worked.
Should I follow the links you sent me earlier now
Re: Airplay issues
Yes please... follow step by step and test... let us know if you run into issues.  The directions is straight forward and should get you going.
Scott
-Scott
Re: Airplay issues
Hi Scott
Thank you so much for your help, once I got the gui working everything else after that was easy, I am hoping I will be able to access the gui in future withough having to go through so many problems.
Just wanted to know oe last thing, if i want to add another access point, i can just connect it to the switch and it will configure automatically as that is what I did for the other 5, once WLC was up all the ap's configured automatically.
Re: Airplay issues
Wanted to add the latest 10.9.2 patch appears to have broken AirPlay on MACs. Just a. FYI
http://appleinsider.com/articles/14/02/27/mac-owners-report-os-x-1092-update-breaks-airplay-functionality
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Re: Airplay issues
Hi George
Thanks for the article. At the moment it works fine for me. I will just leave it as it is for sometime.
Re: Airplay issues
Sure
Http
config network webmode {enable | disable}
Https
config network secureweb {enable | disable}
-Scott
337
