Alternate solution for NAC functionality
Hi Expets ,
In our client setup , they were using the cico NGS 3315 for creating guest accounts . The below are the steps of this process ,
-> Any employee can access corporate web server and can request for guest internet account
->The scripts in the background automatically contacts the guest NAC server with admin username and pwd .
                              http://NAC DNS name/sponsor/api/GuestAccount.php
->Then NAC will reply the credentials to the corporate web server then it will be forwarded to employees's mail account
But the problem is , the NAC server is down . Hence we want to  use the anchor WLC itself to create/authenticate guest accounts  . So kindly confirm this also can be done using script automatically..
Thanks ,
Vijay
Hall of Fame Super Silver
Re: Alternate solution for NAC functionality
You should be able to do the same thing, but your script would have to login to the WLC and add the user.
-Scott
Hi Mr.Scott ,
What will be the exact URL we need to give in the script for anchor WLC.
Whether only ip address is enough or something we need to add extra?
Vijay
Your script would have to telnet or ssh and login to the WLC and then issue the config command to add the user.
-Scott
Thanks Mr.scott , We will try this option will post the update.
Vijay.
We have replaced the NAC box and configured. But we are getting the below errors when the application is trying to create guest account.Kindly suggest
[Wed Nov 06 15:07:42 2013] [error] [client 10.208.31.121] File does not exist: /guest/www/html/favicon.ico
[Wed Nov 06 15:07:49 2013] [error] [client 10.208.31.121] File does not exist: /guest/www/html/favicon.ico
[Wed Nov 06 15:07:57 2013] [error] [client 10.208.31.121] File does not exist: /guest/www/html/favicon.ico
[Wed Nov 06 15:08:45 2013] [error] [client 10.208.31.121] File does not exist: /guest/www/html/guest
[Wed Nov 06 15:08:46 2013] [error] [client 10.208.31.121] File does not exist: /guest/www/html/favicon.ico
[Wed Nov 06 15:20:50 2013] [error] [client 10.201.20.28] File does not exist: /guest/www/html/sponsor/api/GuestAccount.php\xc2\xa0(http:
[Wed Nov 06 15:21:00 2013] [error] [client 10.201.20.28] File does not exist: /guest/www/html/favicon.ico
[Wed Nov 06 15:21:40 2013] [error] [client 10.201.51.19] File does not exist: /guest/www/html/guest
Vijay.
I don't know what your script is doing but the errors you are seeing is from the webauth bundle.
This .ico is a URL image.
-Scott
133
