Anchor connection
Situation -
LAN controler                            WAN                             Firewall                                    Anchor controler
WLC5760                                    <->                             ASA5550               <->             AIR-CTVM-K9 (VM)
On ASA we allow port 16666 and protocol 97
however Coontrol and Data are down
on the FWL i can see proper connection over 16666 however on the FWL i can see message
ASA-4-313005 No matching connection from ICMP error message
connection seems to be from LAN controler to Anchor one
so source 172.21.52.31 to 10.32.34.102 ( type 3, code 2 ). Original IP payload <unknown> -
error seems to be raleted to protocol 97 but don't have a clue what to do with this so any help relly appreciated.
I have attached caputre of this error
WLC5760
interface Vlan100
description Wireless Management Vlan
ip address 172.21.52.31 255.255.254.0
( address is e8ed.f39b.acfd )
wireless management interface Vlan100
wireless mobility group name MOBILITY
wireless mobility group member ip 10.32.34.102 ->
-> public-ip 10.32.34.102 group MOBILITY
Mobility Controller Summary:
Mobility Role                                   : Mobility Controller
Mobility Protocol Port                          : 16666
Mobility Group Name                             : MOBILITY
Mobility Oracle                                 : Disabled
Mobility Oracle IP Address                      : 0.0.0.0
DTLS Mode                                       : Enabled
Mobility Domain ID for 802.11r                  : 0xf2c
Mobility Keepalive Interval                     : 10
Mobility Keepalive Count                        : 3
Mobility Control Message DSCP Value             : 0
Mobility Domain Member Count                    : 2
Link Status is Control Link Status : Data Link Status
Controllers configured in the Mobility Domain:
IP               Public IP        Group Name       Multicast IP     Link Status
172.21.52.31     -                MOBILITY     0.0.0.0          UP   : UP
10.32.34.102     10.32.34.102     MOBILITY     0.0.0.0          DOWN : DOWN
AIR-CTVM-K9
(Cisco Controller) >show mobility anchor
Mobility Anchor Export List
WLAN ID     IP Address            Status
1           10.32.34.102          Up
2           10.32.34.102          Up
2           172.21.52.31          Control and Data Path Down
Controllers configured in the Mobility Group
MAC Address        IP Address                                       Group Name                        Multicast IP                                     Status
00:0c:29:f3:e3:07  10.32.34.102                                     MOBILITY                      0.0.0.0                                          Up
e8:ed:f3:9b:ac:fd  172.21.52.31                                     MOBILITY                      0.0.0.0                                          Control and Data Path Down
Marcin
  • Getting Started with Wireless
VIP Purple
Anchor connection
All new IOS based wrieless controllers (3850, 5760) only support CAPWAP for mobility tunnel, not EoIP. Therefore your anchor controller should support that.
As far as I know 7.3MR1 & 7.5 have this feature (called new mobility) where you can terminate capwap inter-controller mobility tunnels. Not sure whether vWLC support this feature.
Rasika
**** Pls rate all useful responses ****
Re: Anchor connection
According to QA about 5760
Q. In centralized mode with Cisco 5760 WLC or converged access mode, can I support guest anchor functionality?
A. Yes. You can point a Cisco 5760 WLC operating as a mobility controller  to a Cisco 5760 WLC or Cisco 5508 WLC operating as a guest anchor  controller.
Can someone from Cisco provide any info about this ?
VIP Purple
Yes, the above is true, which states a 5760 can do a Guest Anchor functionality where your anchor controller should be either 5760 or a 5508.
If anchor controller is 5508, you should have specific image(7.3MR1 or 7.5) to enable the feature called new mobility. Without that you cannot terminate CAPWAP inter-controller mobility tunnels which is the only mode supported in 5760/3850 (no longer EoIP is supported).
Hope that clear
Rasika
Hi Rasika,
Now everything seems to be clear - of course Cisco change mobility design and of course new one isn't supported on VM version (yet)
Question to somone from Cisco is this future on the road-map for VM version ?
Marcin
271
