Anchored guest clients - web auth and roaming
Good morning!  We have an issue with a guest SSID that is anchored to a WLC in the DMZ.  We have this SSID configured for web-auth with passthrough - clients connect, click 'accept' on our splashpage which then permits internet access.  This process works great.
Where we've run into an issue is with clients roaming.  It appears that the client roams to the next AP (controlled by the foreign WLC) and it's session is maintained as expected on the WLC, however the client session is immediately purged from the anchor WLC.   The only way we've found to restore connectivity for these clients is to either manually remove the entry from the foriegn WLC or configure the foreign WLAN idle timeout to the lowest possible value (15 seconds).
The anchor WLC's WLAN idle timeout is set to 4 hours, which appears to have no bearing on maintaining the client session state once a roam event occurs on the foreign.
All WLC's are v.7.4.100
Any thoughts or suggestions are appreciated.  WLAN cfgs below - foreign first, then anchor.
Anthony
(MM-WiSM2-01) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... MissionHealthGuest-WLAN
Network Name (SSID).............................. MissionHealthGuest
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 277
Exclusionlist Timeout............................ 300 seconds
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ 15 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... MM-WiSM2-01
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ patient-ig
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
Quality of Service............................... Bronze
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Disabled
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11g only
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
--More-- or (q)uit
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Enabled
        IPv4 ACL........................................ Unconfigured
        IPv6 ACL........................................ Unconfigured
        Email Input..................................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Enabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
--More-- or (q)uit
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Disabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Disabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
--More-- or (q)uit
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
2           172...(omitted )          Up
802.11u........................................ Disabled
MSAP Services.................................. Disabled
(DC-5508-Anchor-01) >show wlan 2
Number of Active Clients......................... 492
User Idle Timeout................................ 14400 seconds
--More-- or (q)uit
NAS-identifier................................... DC-5508-Anchor-01
--More-- or (q)uit
Radius Servers
--More-- or (q)uit
Security
--More-- or (q)uit
--More-- or (q)uit
2           172.....(omitted )          Up
Re: Anchored guest clients - web auth and roaming
All the WLC in the network need to be in the mobility list for roaming across WLC to work properly.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Yep, we've definitely got that part configured correctly.  It's only when clients roam from the originating AP they auth'd against to another AP that the session is lost on the anchor.   In case I didnt mention it previously, the client never goes mobile from one WLC to another, rather the session is anchored from on-set.
thanks!
I have a customer reporting the same issues.  It is difficult to troubleshoot as they have two foreign and two anchor controllers.  I don't know what combination I specifically is breaking it, but they also lose web-auth state when they roam.  Let me know if you get any more info.
Were you able to solve this
Were you able to solve this problem for your customer. We are having this same issue you explained here.
Unfortunately no.  The issue
Unfortunately no.  The issue "cooled off" and they are no longer working on it.  Not sure if it was resolved or just became less of a priority.
Similar issue on my side. People with iPhones or iPads complain about having to re-auth (email input) multiple times during a day even if the session timount is set to 4 or 8 hours.
Was the problem addressed or fixed?
Setup is similar: 2 main controllers and 1 anchor. Layer 3 security set to Web Policy, email input, web auth internal.
Hall of Fame Super Silver
Session time-out is a hard timer... you need to adjust your idle time-out to 2-4 hours.  This is an issue with Apple devices more than any others.  When the screen goes blank, the device stops responding and the idle timer starts counting down.  Adjust this to give time for the users to grab lunch, etc... which 2-4 hours is typically what I set.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thanks for teh prompt reply Scott.
Will the change take effect right away, or do I have to cycle off-on the SSID or reboot the controllers?
Claudio
800
