Anntenna for Access point 350
How many antennas needed for the 350 series access pioint ( AIR-AP352E2R-A-K9 ) ?
Can we connect the antenna AIR-ANT4941 directly to the aboce access point ?
Re: Anntenna for Access point 350
You can use one but two you should always have two and are needed for divercity too. Here is the link which discuss about antennas based on features required for Access Points
http://cco/warp/public/cc/pd/witc/ao340ap/prodlit/airoa_ds.htm
Tejal
The 'need' for diversity is rare, so one antenna is almost always sufficient - especially if you are using something better than the stock 2.2dBi antennas.
If you do use more than one high-gain antenna, make sure they are at least one wavelength apart. (Frequency divided by Speed of Light, about 12cm).
Matthew Wheeler
Chief Wireless Architect
www.BlueModal.com
221
