05-07-2003 01:21 PM - edited 07-04-2021 08:41 AM
Does anyone know if there is a document that specifies the ranges for each antenna? I am trying to find out the coverage for a patch antenna.
05-10-2003 07:03 PM
Try this document for range and other properties on several types of antennas compatible with Aironet access points:
08-23-2013 03:34 AM
08-23-2013 05:35 AM
You responded to a post from 2003:)
08-25-2013 08:26 PM
I would recommend you to go through to the below link.
http://www.home.agilent.com/upload/cmc_upload/All/ORFR-Theory.pdf?&cc=IN&lc=eng
http://www.antenna-theory.com/measurements/antenna.php
The above two link will describe how to measure antenna range.
