Antenna Spacing for diversity operation
What is the maximum and minimum spacing that should be used for dual antennas on the cisco 350 Access Point.
1 REPLY
Re: Antenna Spacing for diversity operation
Since diversity mode only exists to defeat mulitpath problems, the antennas cannot be installed (i.e. will not work) in two separate areas - so maximum distance between is a few feet.
For minimum distance, you should be safe at one 2.4GHz wavelength - about 12 centimeters.
Matthew Wheeler
Chief Wireless Architect
www.BlueModal.com
347
