Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
AP 1200 Console - Boots, logs, but does not go to cmd prompt
Hi.
Got an AP1200 - I have a blue cable console connection. I hold the mode button down, reboot, and get a console session. It logs the interfaces for a bit, but then stops and never gives a console prompt. I've tried break, ctl-c, etc...
Any suggestions.
Re: AP 1200 Console - Boots, logs, but does not go to cmd prompt
Check if you use these port settings on your hyperterm:
Speed: 9600 bits per second (bps)
Data bits: 8
Stop bits: 1
Parity: None
Flow Control: Xon/Xoff
Hi, Holding the MODE button down on a reboot resets the AP to factory defaults.
If held for 20 to 30 secs it takes you into the Automatic IOS recovery routine for putting a new IOS image on a AP after a fail. (If held for 20-30 Seconds and middle amber light on front of AP turns RED)
If you want to just get to the prompt set your hyperterminal settings to
Data bits: 8
Parity: None
Stop bits: 1
Flow Control: none
and reboot as normal with no buttons pressed.
Hope this helps
George
317
