Community Member
AP 1230 and VLAN Trunk
Hello
I have a little question about different VLAN's on a AP 1230 and the Trunk between the AP and a switch.
The Situation is, tha we have the VLAN's 1 ( native ), 22, 153 ( voice ) and 192. All VLAN's exists in the wired LAN. The AP is in the IP Range 192.168.192.xxx, which is the VLAN 192. The Ap is connected to a switch catalyst 2948.
Now the question: "In which VLAN do i need put the Trunk between the switch and AP?"
Thank you for your help.
Kind regards
P.Blumenthal
1 REPLY
Bronze
Re: AP 1230 and VLAN Trunk
The trunk should be on the native VLAN. Here is a document that will help with the configuration.
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00801444a1.html
254
