AP 1252AG-E-K9 AP operational status going down
HI Experts ,
I am using a WLC 4404 with 4.2.99.0 software version .
I was trying to addd a new 1252AG-E-K9 ap . the Access point got added succesfully but the radio operational status was going down .
On my WLC i was able to see the message :
Tue Feb 28 09:06:35 2012
AP's Interface:1(802.11a) Operation State Down: Base Radio  MAC:e0:5f:b9:36:be:a2 Cause=Radio Low Power
AP's Interface:0(802.11b) Operation State Down: Base Radio  MAC:e0:5f:b9:36:be:a2 Cause=Radio Low Power
Tue Feb 28 09:06:34 2012
AP Associated. Base Radio MAC: e0:5f:b9:36:be:a2
Can any one  help in geting the issue resolved .
Please let me know whether the Ap is compatible with the current running WLC image version .
Angus
1 REPLY
Re: AP 1252AG-E-K9 AP operational status going down
Angus,
How are you supplying power to your 1252?
PoE port? If so, what mk/model switch?
PoE injector? If so, what mk/model injector?
You should also consider upgrading your controller. 4400 supports up to 7.0.x code.
Justin
317
