AP 1310 and other devices
I would like to connect a AP 1310 to a Orinoco ROR.
I configure the Orinoco ROR as AP and the AP 1310 as Non-Root Bridge, the same SSID, all it's find, but the don't connect.
On the 1310 console i have this message:
Interface Dot11Radio0, cannot associate: No Response.
If i look the channel, it's the same as the orinoco, but they can connect, any idea or suggestions.
Thank's
1 REPLY
Green
Re: AP 1310 and other devices
Bridge and AP are incompatible modes.
Bridge modes are proprietary to the manufacturer. AP modes are standards (802.11b/g/a)
You may be able to get connection by making the bridge a repeater. However, it is likely to reduce your throughput.
Good Luck
Scott
144
